Home > Forums > OpenFOAM Running, Solving & CFD
More than wall function
Old   August 27, 2008, 05:36
Default Hello, In my model, I need
Ivan Lau
ivanwhlau is on a distinguished road
In my model, I need to have two different wall functions because two walls have significant different roughness. Is it possible?
Thanks,
iL
ivanwhlau is offline   Reply With Quote
Old   August 27, 2008, 07:57
Default Yes, it is definitely possible
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Yes, it is definitely possible, as you just define the two boundaries with another type or different properties than those of the other boundaries.
If such a boundary condition is readily available in OF I do not know. It should be fairly straight forward. Try to look into the k-omega for rough surfaces posted in http://www.cfd-online.com/OpenFOAM_D...es/1/5791.html
but be careful I am advertising for my own work and it has not yet been tested/verified.
Best regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   August 27, 2008, 12:36
Default Hi, Niels, Thanks for your
Ivan Lau
Hi, Niels,
Thanks for your reply. I just looked at your thread.
However, I am actually looking for some simpler solution. Currently, there are variables "kappa and E" under wall function of k-epsilon models. I thought I can simply specify different E (small E for smooth surface and higher E for rough surface). I guess I need to modify the code to achieve this. Am I correct?
Best Regards,
iL
Old   August 27, 2008, 13:43
Default I do not know, as I have not u
ngj
I do not know, as I have not used in "build-in" wall function, and thus have not spent time looking into the source.
Best regards,
Niels
Thread Tools
Trackbacks are On
How can I add a new wall function imano OpenFOAM Running, Solving & CFD 14 September 17, 2015 08:53
Bug in wall function rolando OpenFOAM Bugs 7 June 8, 2007 04:51
wall function Alex CFX 9 May 19, 2005 10:05
Does RSM use wall function? Sam Main CFD Forum 4 March 3, 2005 00:58
Wall function Min-Hua Wang CFX 4 July 5, 2002 12:13
