I have a case, where in
I have a case, where in parallel processing certain patches have to be on one processor. I can't use simple or hierarchical as decomposition methods because there I get error messages concerning cellfaces on different processors. How can I define in metis that certain areas or certain patches have to be on one processor? Or how do I define in metis cutting directions? I would be glad for any help!! Bye Diana |
Hi Diana!
The "easiest" way
Hi Diana!
The "easiest" way is to use the manual decomposition method. You'll have to write a utility that assigns every cell to one processor and writes out a list to a file. The manual decompositon method needs that list as a parameter and will only generate the processor-meshes based on that information. All the balancing etc has to be done by your utility. Bernhard |
Hi Bernhard,
thanks for you
Hi Bernhard,
thanks for your tip! I had the same idea, but I never found an information how the datafile has to look like. Can you show me or say how to find information on this? Bye Diana |
Hi Diana,
I am a new user of OpenFoam and I am also finding a way to construct a manual data file. Do you find a way to manage this problem? Thanks Duong |
