Home > Forums > OpenFOAM Running, Solving & CFD
MotionUBoundaryPatch assignment HowTo
Old   October 18, 2011, 10:52
Arne Stahlmann
Arnoldinho is on a distinguished road
Thanks guys, that was fast and helpful!
Although the interpolation is already given now, I will have a closer look into freeSurface.C.
At the moment I'm trying to figure out which of the mesh motion solvers fits my needs best. laplaceFaceDecomposition seems to be used quite often, although I'm not sure if its fast and really works in parallel. If I remember right, I already discussed some bugs with deepsterblue. So far, I tried displacementLaplacian, but already encountered problems with distorted meshes - which of course led to a crash.
Thanks again,
Arne
Arnoldinho is offline   Reply With Quote
Old   October 18, 2011, 11:00
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Arne
My pleasure.
My experience with the mesh motion and morphology/scour is that you need to use laplaceFaceDecomposition, as non of the other methods actually gives you a solution in the boundary layer, which does not invalidate the mesh - even if you constraint the mesh Courant number to say less than 0.2.
- Niels
ngj is offline   Reply With Quote
Old   November 24, 2011, 12:52
Arne Stahlmann
Hi all,
again a question regarding the mesh motion and now esp. the mesh Courant number is coming up:
For long-term simulations of sediment movement and therefore mesh deformation I'm using a procedure of
1. calculate and store the flow and stress field etc. in defined time steps for lets say a period of 1 second
2. loop over the stored flow field values several times (so x times 1s) and solve the sediment transport equation + move the mesh (by modifying motionU bottom boundary patch and updating the mesh afterwards).
The mesh Courant number is calculated each time after the mesh is updated. What I get here, and don't really understand is that the mesh Courant number rises from updating to updating time step within the loop.
I guess that I missed something in the updating process, but am not sure what it is. So is there enything else necessary besides:
- motionU.boundaryField()[patchi] == motionUInterpolator.pointToPointInterpolate();
- mesh.update(); ?
I tested this as well by modifying the interDyMFoam solver by adding a loop over mesh.update() several times. The mesh courant number rises here as well:
DICPCG: Solving for motionUx, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for motionUy, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for motionUz, Initial residual = 5.2212515e-07, Final residual = 8.5333674e-10, No Iterations 27
Mesh Courant Number mean: 0.01134146 max: 0.69139148
Correct mesh motion diffusion field.
DICPCG: Solving for motionUz, Initial residual = 5.0995321e-07, Final residual = 6.895588e-10, No Iterations 27
Mesh Courant Number mean: 0.017007733 max: 1.0168678
DICPCG: Solving for motionUz, Initial residual = 4.9787755e-07, Final residual = 9.5845278e-10, No Iterations 24
Mesh Courant Number mean: 0.022671192 max: 1.3301477
Any explanations?
Arne
Thread Tools
Trackbacks are On
fortran derived type assignment Paolo Lampitella Main CFD Forum 1 September 12, 2008 04:53
Farfield BC assignment BM Main CFD Forum 0 February 4, 2008 14:56
correct assignment of permeability? jemteo CFX 0 March 17, 2006 06:34
UDF memory assignment Kate FLUENT 0 February 2, 2006 09:15
private tuition for a cfd assignment - payment ahmed Main CFD Forum 4 August 10, 2005 09:15
