-   OpenFOAM Running, Solving & CFD (
-   -   Rough baundary in atmospheric wind (
majidhojjat August 18, 2008 09:51
Hi! I am modeling the wind
I am modeling the wind effect on a cubic building. and first, to get the proper approaching flow (similar to experimental data) I am modeling an empty wind channel.
prescribing the inlet velocity, I produce the Ux profile. but for turbulence intensity (or k) using the inlet is not hopeful and I guess I should use a rough wall function to get the desired profile.
I tried using nutStandardRoughWallFunction but it was not really effective. even changing value of roughness length or... did not change anything.
To have a rough wall, is it enough just to add nutStandardRoughWallFunction as the physical type in boundary file and to specify roughness length and other parameters in /0/k ?
I am using OF 1.4.1 and I tried the mentioned problem in kEpsilon and kOmegaSSt as well as LES models.
eugene August 18, 2008 10:11
nut boundary conditions are on
nut boundary conditions are only effective in conjunction with the SpalartAllmaras model.
majidhojjat August 18, 2008 10:30
thank you for your answer, so
so, there is no ready rough wall function to be used in other models?
and to maintain turbulence intensity profile I just have the choice of modifying the inlet values?
eugene August 18, 2008 11:15
For the other models the wall
For the other models the wall functions are hard-coded.
Not sure about the turbulence intensity profile.
