I'm decomposing a tilted cavit
I'm decomposing a tilted cavity (drawn by x):
...xxxx ..x..x .x..x xxxx I know how simple, metis and manual method is used but nothing about hierarchicalCoeffs. I want to decompose the domain with a cutting plane parallel to the tilted sides. Does any one know how hierarchicalCoeffs works or another way to do that. Thanks. /Maka. |
The 'delta' coefficient in hie
The 'delta' coefficient in hierarchical actually rotates the coordinates slightly (so an axis aligned mesh gets does not get a jagged decomposition). Have a look at the source and see whether you can use that / hack it so the coordinates are aligned with your plane.
