Home > Forums > OpenFOAM Running, Solving & CFD
Please help me Moving Boundary
Old   August 12, 2008, 10:51
Default My current project: MovingBoun
Johan Lorentzon
pi06jl6 will become famous soon enough
My current project: MovingBoundary solver have shown not move the grid! the following code is used,
Main code:
// 1/dt
scalar factor=1/(runTime.deltaT().value());
// loop over all boundary points
forAll(fluidMesh.localPoints(),fluidI) {
// get displacement vector shared::icofsi_db.get_displacement(fluidI,patchU[fluidI]);
// calculate dU this gives the motionU on boundary
patchU[fluidI]=factor*patchU[fluidI];
// move mesh, using solver spec by dynamivMesh
mesh.movePoints(motionPtr->newPoints());
#include file:
autoPtr<foam::motionsolver> motionPtr = motionSolver::New(mesh);
tetPointVectorField::GeometricBoundaryField &motionU=const_cast<tetpointvectorfield&>(mesh.obj ectRegistry::lookupObject<tetp ointvectorfield>("motionU")).boundaryField();
Foam::vectorField &patchU=refCast<foam::vectorfield>(motionU[MovingBoundary]);
The result is that the fluid mesh didnt move accordingly the displacement vector i provided as above. Any clue to the error?
Then i use the FEM solver in OF 1.3 which i am not about to use anymore ( xn=x0+dt*dU, velocity solver).
Anyone who can give me anyhint in what solver to use to solve above problem in official 1.4.1/1.5 ( not dev), the case i am working transfer a displacement vector on each point on the moving fluid boundary, then i want to use motionSolver to adjust the mesh in a robust manner since the movement is unknown/moderate large. Further i truly would appriciate a piece of code that i could use as starting point for my implementation.
Thank you for helping me!
PS. I have searched through whole forum and found
no help! However,I have seen the excellent studies of mesh movement. Guessing laplacefacedecompistion should be used but i have no clue how to implement it!
pi06jl6 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Slip Boundary Condition for Moving Boundary Shukla Main CFD Forum 3 November 11, 2005 16:02
moving boundary Wu Guojiang FLUENT 2 August 6, 2005 15:34
Moving Boundary andreis FLUENT 0 April 13, 2005 23:36
moving boundary in CFX 5.7 Gary Wang CFX 7 February 11, 2005 03:28
moving boundary Amir Khanlou FLUENT 0 March 9, 2003 13:04
