-   -   FOAM FATAL IO ERROR (http://www.cfd-online.com/Forums/openfoam-solving/58682-foam-fatal-io-error.html)
msrinath80 October 15, 2006 20:34
Can someone help me with this
Can someone help me with this error message that shows up when I run icoFoam in parallel.
[0] --> FOAM FATAL IO ERROR : Expected a '(' while reading VectorSpace<form,>, found on line 0 the doubleScalar 13.2233
[0]
[0] file: IOstream at line 0.
[0]
[0] From function Istream::readBegin(const char*)
[0] in file db/IOstreams/IOstreams/Istream.C at line 94.
[0]
mattijs October 16, 2006 04:33
Check which file that number i
Check which file that number is in. Something is trying to read a vector/point.
set the environment variable FOAM_ABORT and run the different processes each in a different window in a debugger. Have a look at the lamrun script (posted here before)
msrinath80 October 17, 2006 02:16
Thanks Mattijs. I solved the p
Thanks Mattijs. I solved the problem somehow. I'll soon post the solution here. Once again, I appreciate your help http://www.cfd-online.com/OpenFOAM_D...part/happy.gif
mgz1985 July 30, 2008 06:07
hi pUI, relating to ur post
hi pUI,
relating to ur post of doubleScalar errors, can u plese tell me the solutionas i m facing the same problem while defining a arc or a spline as an edge in openfoam 1.5
msrinath80 July 30, 2008 10:06
Hi Mayanak, My sincere apol
Hi Mayanak,
My sincere apologies. It was a long time ago and I'm not sure if I remember what I did to overcome the problem. I do remember that this was something to do with a wrong definition in one of the dictionary files, not to do with any code. I'll try to look into my scrap notes and see if I can figure this out. Once again, very sorry.
