July 18, 2007, 00:17 |
OK, with 1.4 version it seems
Rep Power: 18 |
OK, with 1.4 version it seems there is a bug.
CheckYPlus does not work, it requires 'p' file form time-step directory, which in 1.4 version is called 'pd'. Looks like a simple thing, but I'm not familiar with OpenFOAM code yet, so I leave it for others BTW. Why version 1.4 seems to be so buggy? Quite often I can read somebody complaints something does not work or is missing. Regards, K |
July 18, 2007, 03:07 |
"but I'm not familiar with Ope
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
"but I'm not familiar with OpenFOAM code yet, so I leave it for others"
In that case I would recommend you keep your expert comments to yourself. If you can contribute in a way that is productive please do so, if not then please stop ranting about the code being buggy. |
July 18, 2007, 14:42 |
"expert comments" - that's wha
Rep Power: 18 |
"expert comments" - that's what I "like" about some people.
BTW. I am not ranting, just stating the fact that something doesn't work. No more comments. |
July 19, 2007, 07:04 |
Foam has various pressure defi
Eugene de Villiers
Rep Power: 21 |
Foam has various pressure definitions which makes writing general utilities cumbersome in some instances.
Specifically, p can be absolute pressure, kinematic pressure (p/rho) or pd - pressure without the gravity component. checkYPlus was written to work with incompressible flow with pressures of the type p/rho only. This has always been the case and is certainly not a bug introduced in 1.4. It will not and has never worked with interFoam, buoyantFoam or other compressible solution fields. Feel free to modify it do do so though. |
July 30, 2008, 04:18 |
where is checkYPlus gone in Op
Stefan Radl
Rep Power: 18 |
where is checkYPlus gone in OpenFOAM 1.5?
br Stefan Radl |
July 30, 2008, 04:34 |
Try yPlusLES or yPlusRAS
An
Andrew King
Andrew
Dr Andrew King Fluid Dynamics Research Group Curtin University |
