Execution time problem after first write interval
Old   July 25, 2008, 14:46
Default Hi, I am currently running Op
Sean McIntyre
sean_mcintyre is on a distinguished road
I am currently running OpenFOAM 1.4.1, and have been experiencing a problem with the solvers (currently rasInterFoam, though it has shown up with other solvers as well). When running parallel jobs, the execution time increases from about 15 seconds per time step to about 10000 seconds after the first write interval, and stays that way. Upon upgrading to 1.5, we still experienced the problem, which doesn't happen in single processor jobs. In 1.4.1-dev, it was less notable, only about doubling the execution time. Has anyone else been experiencing the same problems? If so, do you have any idea what's the cause? I have used both LAM and OpenMPI, and had the same problem.
Thanks,
Sean McIntyre
sean_mcintyre is offline   Reply With Quote
Old   July 28, 2008, 04:36
Default Hi Sean, We've had the same
Roland
sylvester is on a distinguished road
Hi Sean,
We've had the same problem. It was related to an NFS bug in the RedHat kernel. I don't know which version, but updating the kernel solved our problem.
Sylvester
sylvester is offline   Reply With Quote
Old   July 28, 2008, 05:12
Default I can confirm this. I think it
Eugene de Villiers
eugene is on a distinguished road
I can confirm this. I think it was RHEL 4 update 3. We never found out why it happened only with OpenFOAM though.
eugene is offline   Reply With Quote
Old   July 28, 2008, 08:46
Default Thank you so much! I'll have
Sean McIntyre
Thank you so much! I'll have to see if our HPC person can update the kernel for us. We wanted to just blame LAM, but it happened with the MPI too. Thanks again,
Sean McIntyre
Is there a way to write the time step size, time a may FLUENT 6 November 22, 2009 11:52
why did my time interval set for output nouse? ShFlow FLOW-3D 2 January 11, 2009 20:25
Reading case file at certain time interval Chin Fook FLUENT 1 September 11, 2008 06:54
Measuring an Execution Time - f90 su Main CFD Forum 11 July 4, 2008 07:21
Execution problem Jiri Siemens 3 October 16, 2003 09:46
