Home > Forums > OpenFOAM Running, Solving & CFD
RealizableKE
Old   November 7, 2005, 06:11
Default Sorry, but I can't find anywhe
Canelli Claudio
cfdengineering is on a distinguished road
Sorry, but I can't find anywhere a default set of values for the compressible realizable k-epsilon model:
Cmu
A0
C2
alphak
alphaEps
alphah
can anybody help me?
thanks
cfdengineering is offline   Reply With Quote
Old   November 11, 2005, 04:41
Default From paper by Shih et al. (Com
Niklas Wikstrom
wikstrom is on a distinguished road
From paper by Shih et al. (Computers and Fluids Vol. 24, No. 3, pp. 227-238, 1995) it seems to be
realizableKECoeffs
Cmu Cmu [0 0 0 0 0 0 0] 0.09;
A0 C1 [0 0 0 0 0 0 0] 4.0;
C2 C2 [0 0 0 0 0 0 0] 1.92;
alphak alphaK [0 0 0 0 0 0 0] 1.0;
alphaEps alphaEps [0 0 0 0 0 0 0] 1.2;
/N
wikstrom is offline   Reply With Quote
Old   August 14, 2006, 11:49
Default Seems like there are some miss
stefan
stefanke is on a distinguished road
Seems like there are some missing entries like alphah etc.
Does anybody know the realiableKECoeff ?
I cannot find any references in OF?
stefanke is offline   Reply With Quote
Old   August 14, 2006, 11:51
Default realizableKECoeffs { Cmu
Hrvoje Jasak
realizableKECoeffs
A0 A0 [0 0 0 0 0 0 0] 4.04;
alphak alphak [0 0 0 0 0 0 0] 1.0;
alphaEps alphaEps [0 0 0 0 0 0 0] 0.76923;
Hrvoje Jasak
Old   August 14, 2006, 11:56
Default thanks Hrv, but with this setu
stefan
thanks Hrv, but with this setup the following error occurs:
keyword alphah is undefined in dictionary "
in turbulenceProperties::realizableKECoeffs"
Old   August 14, 2006, 12:40
Default the coefficient alphah is used
Pierre Le Fur
pierre is on a distinguished road
the coefficient alphah is used to evaluate the effective turbulent thermal diffusivity. (see realizableKE.h)
just add alphah alphah [0 0 0 0 0 0 0] 1;
as in
realizableKECoeffs
pierre is offline   Reply With Quote
Old   August 29, 2007, 03:13
Default I have a question about the re
Roland
sylvester is on a distinguished road
I have a question about the relationship between the value of sigmaEps given by Shih (1.2) and the value of alphaEps given by Jasak (0.76923).
With these values alphaEps = 1 / (sigmaEps + 0.1), but where does the 0.1 come from?
I have studied the equations in the Shih paper and realizable.C, but there is too much mathematical wizardry going on for me to fully understand it.
Thank you.
Sylvester
sylvester is offline   Reply With Quote
Old   July 12, 2008, 12:13
Default Dear Foamers, to clarify th
sradl's Avatar
Stefan Radl
sradl is on a distinguished road
Dear Foamers,
to clarify the situation the following should be noted:
OpenFOAM's implementation of the realizable k-e model does not strictly follow the paper of Shih et al. and the coefficients proposed in it:
sigmaEps is 1.3 in OF (and hence 1/sigmaEps = alphaEps = 0.76923), whereas Shih et al. [1] propose sigmaEps = 1.20 (see Eqn. 28 of their paper). Furthermore, OF uses C2=1.92 whereas Shih et al. [1] use 1.9 (see table 2 of their paper). These two deviations may be errors or may be introduced by the programmers/users to be consistent with the standard k-e model.
Also A0 is 4.0 in Shih et al. [1] and not 4.04 as proposed here. (However, the value of 4.04 is consistent with www.cfd-online.com/Wiki while the others are not).
It seems that all equations are consistent with the paper of Shih et al. [1] except the fact, that OF uses (nut/sigmak+nu) and (nut/sigmaEps+nu) instead of (nut/sigmak) and (nut/sigmaEps) as in the paper of Shih et al. [1] respectively. This is of course a small effect and should not have any further consequences at high Re-number flows.
I hope this clarifies the parameters of the OF realizableKE model and I would like to suggest to include a clarification in the next release of OF.
Reference:
[1]Tsan-Hsing Shih, William W. Liou, Aamir Shabbir, Zhigang Tang and Jiang Zhu. 1995. A New k-epsilon Eddy Viscosity Model for High Reynolds Number Turbulent Flows, Computers and Fluids 24. 227-238.
sradl is offline   Reply With Quote
Old   March 28, 2011, 16:09
vaina74 is on a distinguished road
Hi, foamers.
I have two question about realizable k-epsilon turbulent model. I included in RASProperties file the following coefficients (I found them in realizableKE.H):
realizableKECoeffs
    Cmu         0.09;
    A0          4.0;
    C2          1.9;
    alphak      1.0;
    alphaEps    0.833333;
    alphah      1.0;    // only for compressible
What is the difference from Mr Hjasak (respect!) suggested ones?
Anyway, I obtain the following error:
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model realizableKE
[0]
[0]
[0] LHS and RHS of + have different dimensions
     dimensions : [0 0 -1 0 0 0 0] + [0 2 -3 0 0 0 0]
[0]
[0]
[0]     From function operator+(const dimensionSet& ds1, const dimensionSet& ds2)
[0]     in file dimensionSet/dimensionSet.C at line 403.
[0]
FOAM parallel run aborting
What does it mean?
Thanks for your attention.
vaina74 is offline   Reply With Quote
Old   March 31, 2011, 03:45
It means I'm an idiot. The realizableKE coefficients are correct, but I derived /0/epsilon from /0/omega (it was an 'old' case) and I forgot to edit the units too.
Thread Tools
Trackbacks are On
