June 11, 2007, 10:00 |
Hi.
Been playing with combu
Simon Stapleton
Hi.
Been playing with combustion simulations, based on the XiFoam/moriyoshiHomogeneous and Xoodles/pitzDaily tutorial cases. Xoodles would seem to be more suited to my case, as it happens, but I see the same issue in both. Rather than a simple 2d case, mine is a wedge slice, 5°, axially symmetric around the Z axis and with one cell over the XZ plane (i.e. once cell defined between a surface rotated 2.5° back in the Y direction and another rotated 2.5° forwards. If I run the sim without combustion happening, all is well; flows happen as I would expect in a non-combustion case. However, when combustion happens, I rapidly hit the dreaded "out of temperature range" error (sooner or later, depending on how many cells end up getting ignited). I've tried setting adjustable time steps and a low maxCo, but to no avail... Is this a known issue with wedge cases, or am I doing something insanely wrong? My initial boundary conditions look right, and match the tutorial cases WRT walls and inlets / outlets; the tutorial cases themselves run happily. Geometry aside, the only difference I can see is that by bounding surfaces are marked as "wedge" rather than "empty". Simon |
July 8, 2008, 04:51 |
Hi simon
I have that problem
a_tavasoly
Hi simon
I have that problem with a axymetric bunsen burner with Xifoam. Do your problem solved? by. |
Dimension issues using CEL | Andy | CFX | 4 | April 8, 2008 06:49 |
Miscellaneous Issues | Hamdy | Phoenics | 1 | March 17, 2006 06:52 |
two issues on cfd | guang ai | Main CFD Forum | 1 | March 16, 2006 07:24 |
RSM issues | Jonathan Vogt | FLUENT | 1 | August 11, 2005 05:33 |
CFD Technology Issues | CFDsurvey | Main CFD Forum | 2 | July 7, 1998 00:56 |
