Convergence with MRFSimpleFoam
Old   October 3, 2007, 12:13
Default Hi all, I have created a thre
Gabriele Ruggieri
grugg is on a distinguished road
I have created a three-dimensional fuel rotating pump leaving from the MRFSimpleFoam tutorial in OpenFoam-1.4.1. There are two regions, one cylindrical inner that rotates at 720 rad/s and one external fixed. They are connected with three interfaces ggi: one on top, one lateral and one on bottom. There is also inlet and outlet.
The MRFZones are defined like in the tutorial with rotor and stator.
After one timeStep the residual value increse and I don't know why.
I have tried the mixer2d icoDyMFoam tutorial and a lot of other cases with this method and they work very well.
Here there are the log file, p, U and MRFZones
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : MRFSimpleFoam . pump
Date : Oct 03 2007
Time : 15:22:47
Host : sarge
PID : 27336
Root :
/gamma/grugg/OpenFOAM/OpenFOAM-1.4.1/tutorials/MRFSimpleFoam
Case : pump
Nprocs : 1
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model laminar
Starting time loop
Time = 1
smoothSolver: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 1
PCG: Solving for p, Initial residual = 1, Final residual = 9.85725e-07, No Iterations 767
PCG: Solving for p, Initial residual = 0.00230797, Final residual = 9.98469e-07, No Iterations 148
PCG: Solving for p, Initial residual = 0.000382438, Final residual = 9.98736e-07, No Iterations 297
PCG: Solving for p, Initial residual = 8.68112e-05, Final residual = 9.9683e-07, No Iterations 15
PCG: Solving for p, Initial residual = 2.74264e-05, Final residual = 9.87837e-07, No Iterations 8
time step continuity errors : sum local = 4.03381, global = -0.0905555, cumulative = -0.0905555
ExecutionTime = 91.13 s ClockTime = 92 s
Time = 2
PCG: Solving for p, Initial residual = 0.997299, Final residual = 0.393761, No Iterations 7000
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 106000;
boundaryField
inlet
type totalPressure;
p0 uniform 106000;
U U;
phi phi;
rho none;
psi none;
gamma 1.0;
outlet
type outletInlet;
outletValue uniform 106066;
rotor
type zeroGradient;
stator
type zeroGradient;
outsideSliderTop
type ggi;
outsideSliderBottom
type ggi;
outsideSliderLateral
type ggi;
insideSliderTop
type ggi;
insideSliderBottom
type ggi;
insideSliderLateral
type ggi;
FoamFile
version 2.0;
format ascii;
root "/gamma/grugg/OpenFOAM/OpenFOAM-1.4.1/tutorials/MRFSimpleFoam";
case "pompaGRUGG_2";
instance "0";
local "";
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
rotor
type fixedValue;
value uniform (0 0 0);
insideSliderTop
type ggi;
insideSliderLateral
type ggi;
insideSliderBottom
type ggi;
stator
type fixedValue;
outsideSliderTop
type ggi;
type ggi;
outsideSliderBottom
type ggi;
inlet
type pressureInletVelocity;
outlet
type inletOutlet;
inletValue uniform (0 0 0);
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class dictionary;
object MRFZones;
1
rotor
patches (rotor);
origin origin [0 1 0 0 0 0 0] (0 0 0);
axis axis [0 0 0 0 0 0 0] (0 0 1);
omega omega [0 0 -1 0 0 0 0] 720;
First region, omega = 720 rad/s
rotor (blades)
insideSliderTop
insideSliderLateral
insideSliderBottom
Second region, fixed
stator (external wall)
outsideSliderTop
outsideSliderBottom
inlet
outlet
Please can anyone help me ?
I'm sorry, my english is not good.
Thanks
Gabriele
grugg is offline   Reply With Quote
Old   March 29, 2008, 10:07
Default hi: have you ever resolve yo
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
hi:
have you ever resolve your problem?try to modify the initial condition?
waynezw0618 is offline   Reply With Quote
Old   June 26, 2008, 10:02
Default MRFSimpleFoam computes relativ
David Hora
david is on a distinguished road
MRFSimpleFoam computes relative fluxes for the cell faces of the rotating frame. The affected faces are listed in faceZones. I assume that the flux is treated as absolute for the control surfaces of the ggi interface. Does anybody know it more precisely and how would it be possible to make the fluxes relative at the interface?
Regards
david
david is offline   Reply With Quote
Old   June 19, 2010, 12:27
Default MRFSimpleFoam 2nd order convergence
Aldo Iannetti
aldo.iannetti is on a distinguished road
Hi
I'm trying to simulate a 3D cooling fan using OF 1.6 and MRFSimpleFoam, I'm interested in a second order upwind solution.
My grid is 3D, unstructured, tetraedral and imported from GAMBIT. The rotational velocity has been given step by step growing from 50 rad/s to 272 rad/s. Residuals go down till 4000 iterations after that they start to increase and diverge. Here attached my fvSchemes and the log file.
Can you please give me advices about settings (under relaxation, discretization schemes etc..)
Thanks
aldo.iannetti is offline   Reply With Quote
Old   July 19, 2010, 23:16
Default Convergence issues
hm86 is on a distinguished road
I am running MRFSimpleFoam on a wind turbine blade using the Spallart-Allmaras turbulence model. I am using inletOutlet BCs on p, U, rho and fixedValues of nut and nuTilda on the outer boundary but after 300 iterations the residuals begin to diverge and eventually blow up. Has anyone seen this before or have any idea why this is happening?
hm86 is offline   Reply With Quote
Old   March 28, 2014, 03:43
Default Turbulence convergence problems
Ilya
skeptik is on a distinguished road
I have had all described problems in my 2-blade rotor case.
It seems that the solution should be such as written below:
1. upwind schemes for K and Omega
2. low 1e-6 meanings for both variables at inlets and openings, at walls i've left it for a small value corellate to velocity of the wall. I used wallFunctions.
practice makes perfect
skeptik is offline   Reply With Quote
Old   March 28, 2014, 04:21
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
Hi Ilya,
First of all your question is not clear, no body have time to read all the post from the beginning, so be specific about your problem, as well the thread you chosen is nearly 4 years old, the people involved in that discussion may have forgotten the solution to the problem, try to find the latest thread or else start new one.
there are few questions
--> are you using wall function? or resolving boundary layer?
if you are intending to use wall function, the value for k and omega should be estimated in standard way.
In the case of Low Re (resolving boundary layer), you should give k and Omega small value 1e8.
For turbulent quantities, first order upwind scheme is recommended.
if this answer didt help you, please post you problem clearly.
Thanks,
Sivakumar
sivakumar is offline   Reply With Quote
Old   March 28, 2014, 04:56
Ilya
Originally Posted by sivakumar View Post
Hi Ilya,
Thanks,
Sivakumar
1. Of course people from this theme forgot their cases, but for newest ones google is working.
2. Yes, i'm using wall functions and all variables are calculated but it needs initial values anyway.
3. Despite to my suggestions problem stands still. OpenFOAM does not crash due to high k and omega but pressure field is not realistic.
Equations in the MRFsimpleFOAM waynezw0618 OpenFOAM Running, Solving & CFD 5 May 7, 2015 04:43
MRFSimpleFoam Tutorial bastil OpenFOAM Running, Solving & CFD 48 August 1, 2012 10:00
MRFSimpleFoam PropellerMixer tino_boelke OpenFOAM Running, Solving & CFD 0 December 17, 2008 10:25
MRFSimpleFoam xdanielx OpenFOAM Running, Solving & CFD 0 December 17, 2008 01:28
MRFSimpleFoam with 2 rotors tommie OpenFOAM Running, Solving & CFD 3 December 16, 2008 10:57
