June 24, 2008, 05:15 |
hi everibody,
I'm tryng to si
Carlo De Angelis
Rep Power: 17 |
hi everibody,
I'm tryng to simulate a waterfall with rasInterFoam and I'd like to compare these results with another simulation made with Fluent. As BC at the atmosphere in Fluent I have pressureoutlet, in which I can set Turbulent Intesity and Viscosity Ratio. But if I set pressure outlet in Openfoam I have zerogradient for k and epsilon at the BC, and what I see is that k and epsilone go to zero in the domain while in Fluent they are constant. Could someone give me some advice on which BC could I set to replicate the same case thate I have in Fluent. Thank you Best regards Carlo |
January 28, 2010, 05:45 |
Rep Power: 16 |
I would also be interested in this question.
I have a pipe flow with a fix inlet velocity and pressure. At the outlet I want to have the resulting pressure, but with zeroGradient it doesn't seem to work so fine. Shouldn't it also be able with pressureOutlet - but therefor I need a entry for value, but which? Regards! |
operating pressure and pressureoutlet | free | FLUENT | 2 | April 14, 2004 17:17 |
