How to have the Inlet and Outlet swap places periodically during a simulation? |
May 3, 2018, 22:08 |
Andrew
Rep Power: 7 |
Hi all,
I have a problem whereby I want the fluid to flow from left to right in a channel, entering the channel from the inlet on the left to an outlet on the right of pressure zero, I then want the fluid to flow from right to left, entering what was the outlet to flow out through what was initially the inlet. How can I achieve this? |
May 7, 2018, 13:18 |
This sounds like it can be solved either by swak4Foam or Function1 types of boundary conditions. The 3rd option you have would be coding a new boundary condition. Probably I would go for swak4Foam (groovyBC). Regards, Tom |
Pressure Boundary Inlet and Outlet | AS_Aero | CFX | 5 | March 28, 2018 10:46 |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 06:42 |
simpleFoam: Non-uniform mesh near inlet & outlet causes incorrect velocity profile? | Zaphod'sSecondHead | OpenFOAM Running, Solving & CFD | 0 | January 28, 2015 05:17 |
Fan geometry for simulation with inlet and outlet duct | chaudhry_hashim | STAR-CCM+ | 0 | July 2, 2014 02:52 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
