-   -   Errors in compling icoFsiFoam (http://www.cfd-online.com/Forums/openfoam-solving/58840-errors-compling-icofsifoam.html)
jin_xu May 29, 2008 18:08
Hi everybody, for my gradua
Hi everybody,
for my graduation project, which is similar to the bentpipe case , I am trying to find a FSI solver and find icoFsiFoam is the one I should use.
I am just started with OF, so I just downloaded all the files and try to compile it using "wmake", but I end up with errors, Could anyone give me some ideas? I will really appreciate your help!
(I am using OF-1.3 )
snail@snail-laptop:~/OpenFOAM/snail-1.3/applications/solvers/icoFsiFoam$ wmake
make: Nothing to be done for `allFiles'.
make: `Make/linuxGcc4DPOpt/dependencies' is up to date.
SOURCE_DIR=tractionDisplacement
SOURCE=tractionDisplacement/tractionDisplacementFvPatchVectorField.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/home/snail/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/snail/OpenFOAM/OpenFOAM-1.3/src/dynamicFvMesh/lnInclude -I/home/snail/OpenFOAM/OpenFOAM-1.3/src/dynamicMesh/lnInclude -DFACE_DECOMP -I/home/snail/OpenFOAM/OpenFOAM-1.3/src/tetDecompositionFiniteElement/lnInclude -I/home/snail/OpenFOAM/OpenFOAM-1.3/src/tetDecompositionMotionSolver/lnInclude -I/home/snail/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/tractionDisplacementFvPatchVectorField.o
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:75: error: expected ',' or '...' before '<' token
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:76: error: ISO C++ forbids declaration of 'DimensionedField' with no type
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:82: error: expected ',' or '...' before '<' token
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:84: error: ISO C++ forbids declaration of 'DimensionedField' with no type
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:84: error: 'Foam::tractionDisplacementFvPatchVectorField::tra ctionDisplacementFvPatchVect orField(const Foam::fvPatch&, int)' cannot be overloaded
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:76: error: with 'Foam::tractionDisplacementFvPatchVectorField::tra ctionDisplacementFvPatchVect orField(const Foam::fvPatch&, int)'
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:92: error: expected ',' or '...' before '<' token
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:94: error: ISO C++ forbids declaration of 'DimensionedField' with no type
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:115: error: expected ',' or '...' before '<' token
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:116: error: ISO C++ forbids declaration of 'DimensionedField' with no type
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:121: error: expected ',' or '...' before '<' token
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:122: error: ISO C++ forbids declaration of 'DimensionedField' with no type
tractionDisplacement/tractionDisplacementFvPatchVectorField.H: In member function 'virtual Foam::tmp<foam::fvpatchfield<foam::vector<double> > > Foam::tractionDisplacementFvPatchVectorField::clon e(int) const':
tractionDisplacement/tractionDisplacementFvPatchVectorField.H:126: error: 'iF' was not declared in this scope
tractionDisplacement/tractionDisplacementFvPatchVectorField.C: At global scope:
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:42: error: expected ',' or '...' before '<' token
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:43: error: ISO C++ forbids declaration of 'DimensionedField' with no type
tractionDisplacement/tractionDisplacementFvPatchVectorField.C: In constructor 'Foam::tractionDisplacementFvPatchVectorField::tra ctionDisplacementFvPatchVect orField(const Foam::fvPatch&, int)':
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:45: error: 'iF' was not declared in this scope
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:59: error: expected ',' or '...' before '<' token
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:61: error: ISO C++ forbids declaration of 'DimensionedField' with no type
tractionDisplacement/tractionDisplacementFvPatchVectorField.C: In constructor 'Foam::tractionDisplacementFvPatchVectorField::tra ctionDisplacementFvPatchVect orField(const Foam::tractionDisplacementFvPatchVectorField&, const Foam::fvPatch&, int)':
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:63: error: 'iF' was not declared in this scope
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:63: error: 'mapper' was not declared in this scope
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:73: error: expected ',' or '...' before '<' token
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:75: error: ISO C++ forbids declaration of 'DimensionedField' with no type
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:75: error: redefinition of 'Foam::tractionDisplacementFvPatchVectorField::tra ctionDisplacementFvPatchVect orField(const Foam::fvPatch&, int)'
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:43: error: 'Foam::tractionDisplacementFvPatchVectorField::tra ctionDisplacementFvPatchVect orField(const Foam::fvPatch&, int)' previously defined here
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:77: error: 'iF' was not declared in this scope
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:78: error: 'dict' was not declared in this scope
tractionDisplacement/tractionDisplacementFvPatchVectorField.C: In copy constructor 'Foam::tractionDisplacementFvPatchVectorField::tra ctionDisplacementFvPatchVect orField(const Foam::tractionDisplacementFvPatchVectorField&)':
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:90: warning: base class 'class Foam::lduCoupledInterface' should be explicitly initialized in the copy constructor
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:102: error: expected ',' or '...' before '<' token
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:103: error: ISO C++ forbids declaration of 'DimensionedField' with no type
tractionDisplacement/tractionDisplacementFvPatchVectorField.C: In constructor 'Foam::tractionDisplacementFvPatchVectorField::tra ctionDisplacementFvPatchVect orField(const Foam::tractionDisplacementFvPatchVectorField&, int)':
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:105: error: 'iF' was not declared in this scope
tractionDisplacement/tractionDisplacementFvPatchVectorField.C: In member function 'virtual void Foam::tractionDisplacementFvPatchVectorField::upda teCoeffs()':
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:172: error: 'const class Foam::fvPatch' has no member named 'lookupPatchField'
/home/snail/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/fvPatchField.H: In static member function 'static Foam::tmp<foam::fvpatchfield<type> > Foam::fvPatchField<type>::addpatchConstructorToTab le<fvpatchfieldtype>::New(cons t Foam::fvPatch&, const Foam::Field<type>&) [with fvPatchFieldType = Foam::tractionDisplacementFvPatchVectorField, Type = Foam::Vector<double>]':
/home/snail/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/fvPatchField.H:108: instantiated from 'Foam::fvPatchField<type>::addpatchConstructorToTa ble<fvpatchfieldtype>::addpa tchConstructorToTable() [with fvPatchFieldType = Foam::tractionDisplacementFvPatchVectorField, Type = Foam::Vector<double>]'
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:197: instantiated from here
/home/snail/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/fvPatchField.H:108: error: no matching function for call to 'Foam::tractionDisplacementFvPatchVectorField::tra ctionDisplacementFvPatchVect orField(const Foam::fvPatch&, const Foam::Field<foam::vector<double> >&)'
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:103: note: candidates are: Foam::tractionDisplacementFvPatchVectorField::trac tionDisplacementFvPatchVectorF ield(const Foam::tractionDisplacementFvPatchVectorField&, int)
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:90: note: Foam::tractionDisplacementFvPatchVectorField::trac tionDisplacementFvPatchVectorF ield(const Foam::tractionDisplacementFvPatchVectorField&)
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:61: note: Foam::tractionDisplacementFvPatchVectorField::trac tionDisplacementFvPatchVectorF ield(const Foam::tractionDisplacementFvPatchVectorField&, const Foam::fvPatch&, int)
tractionDisplacement/tractionDisplacementFvPatchVectorField.C:43: note: Foam::tractionDisplacementFvPatchVectorField::trac tionDisplacementFvPatchVectorF ield(const Foam::fvPatch&, int)
/home/snail/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/fvPatchField.H: In static member function 'static Foam::tmp<foam::fvpatchfield<type> > Foam::fvPatchField<type>::addpatchMapperConstructo rToTable<fvpatchfieldtype>::Ne w(const Foam::fvPatchField<type>&, const Foam::fvPatch&, const Foam::Field<type>&, const Foam::fvPatchFieldMapper&) [with fvPatchFieldType = Foam::tractionDisplacementFvPatchVectorField, Type = Foam::Vector<double>]':
/home/snail/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/fvPatchField.H:117: instantiated from 'Foam::fvPatchField<type>::addpatchMapperConstruct orToTable<fvpatchfieldtype>: :addpatchMapperConstructorToTable() [with fvPatchFieldType = Foam::tractionDisplacementFvPatchVectorField, Type = Foam::Vector<double>]'
/home/snail/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/fvPatchField.H:117: error: no matching function for call to 'Foam::tractionDisplacementFvPatchVectorField::tra ctionDisplacementFvPatchVect orField(const Foam::tractionDisplacementFvPatchVectorField&, const Foam::fvPatch&, const Foam::Field<foam::vector<double> >&, const Foam::fvPatchFieldMapper&)'
/home/snail/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/fvPatchField.H: In static member function 'static Foam::tmp<foam::fvpatchfield<type> > Foam::fvPatchField<type>::adddictionaryConstructor ToTable<fvpatchfieldtype>::New (const Foam::fvPatch&, const Foam::Field<type>&, const Foam::dictionary&) [with fvPatchFieldType = Foam::tractionDisplacementFvPatchVectorField, Type = Foam::Vector<double>]':
/home/snail/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/fvPatchField.H:131: instantiated from 'Foam::fvPatchField<type>::adddictionaryConstructo rToTable<fvpatchfieldtype>:: adddictionaryConstructorToTable() [with fvPatchFieldType = Foam::tractionDisplacementFvPatchVectorField, Type = Foam::Vector<double>]'
/home/snail/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/fvPatchField.H:131: error: no matching function for call to 'Foam::tractionDisplacementFvPatchVectorField::tra ctionDisplacementFvPatchVect orField(const Foam::fvPatch&, const Foam::Field<foam::vector<double> >&, const Foam::dictionary&)'
make: *** [Make/linuxGcc4DPOpt/tractionDisplacementFvPatchVectorField.o] Error 1
gschaider May 30, 2008 03:56
Hi Jin! I THINK the issues
Hi Jin!
I THINK the issues you are experiencing are due to trying to compile 1.4-boundary conditions on a 1.3 installation.
The icoFsiFoam you got is from Hrv's dev-version, isn't it?
I just tried to compile that on a vanilla 1.4.1 and it won't work there too (because it uses some stuff that was removed). So if you don't want to use the whole dev-version have a look at old versions under
https://openfoam-extend.svn.sourcefo...end/tags/Core/
maybe the 1.3-version found there (or even the 1.4) works for you
Bernhard
jin_xu May 30, 2008 06:21
Hi Bernhard, I replaced all
Hi Bernhard,
I replaced all my files with the icoFsiFoam version "OpenFOAM-1.4.1_dev_07_11_14/"
the old errors are gone, but new one appears:
setMotion.H: In function 'int main(int, char**)':
setMotion.H:30: error: 'class Foam::tetPolyPatchInterpolation' has no member named 'pointToPointInterpolate'
make: *** [Make/linuxGcc4DPOpt/icoFsiFoam.o] Error 1
I think maybe the reason is that in OF 1.3, there is no member function named "pointToPointInterpolate" for Foam::tetPolyPatchInterpolation. so I am thinking that, if I install a OF 1.4, maybe the erros will be eliminated.
Can you give me some ideas?
Kind regards
jin
jin_xu May 30, 2008 20:29
Hi, everybody, I also compi
Hi, everybody,
I also compile the icoFsiFoam in OpenFOAM-1.3_dev_07_08_29/, the same error appears:
i don't know why Foam::tetPolyPatchInterpolation misses this member funtion, as I have noticed, this member funtion is used in every icoFsiFoam in different OF version. so this member should exit, but I do not know how can i help the class to find this member function, could anybody give me some ideas?
Thanks in advance,
jin
jin_xu May 31, 2008 08:45
Hi, everybody, the problem
Hi, everybody,
the problem is solved.^_^I download another version of OF-1.3 which is precompiled by Pro.Jasak and contains the missing member function in the OF-1.3 downloaded in the official website.so the icoFsiFoam is succesfully compiled.
However, there is no turorial case for this solver, could anyone give me some ideas on how to orgnize the directory structure for a icoFsiFoam case?
Thanks in advance!
Regards
jin
jin_xu June 4, 2008 20:15
Hi everybody, I think I hav
Hi everybody,
I think I have made some progress on icoFsiFoam,but I still have questions:
(1) in the controlDic, what we should we put for the applicationClass(now I use icoFoam, is that right?), but for icoStructFoam, it is "laplacianFoam".
(2) why should we have the file "sampleDict"
(3)how does the file "tetFemSolution" work?
and I am trying to run a deformable channel case(describled in Wiki) and compare it with the one I get from modified icoStructFoam for validation. Now I can run this case but the computation is unstable and I still get one waring which I don't know how to fix:
--> FOAM Warning :
From function objectRegistry::checkIn(regIOobject&)
in file db/objectRegistry/objectRegistry.C at line 51
Registering object 'solid' with objectRegistry 'time'
This is only appropriate for registering the regions of a multi-region computation
or in other special circumstances.
Otherwise please register this object with its region (mesh)
The computation output is:
Time = 0.608
Setting pressure
x-component of total pressure force = nan
ICCG: Solving for Ux: solution singularity
ICCG: Solving for Uy: solution singularity
ICCG: Solving for Uz: solution singularity
ICCG: Solving for motionUx: solution singularity
ICCG: Solving for motionUy: solution singularity
ICCG: Solving for motionUz: solution singularity
Motion magnitude: mean = nan max = nan
Courant Number mean: nan max: nan
BICCG: Solving for Ux: solution singularity
BICCG: Solving for Uy: solution singularity
BICCG: Solving for Uz: solution singularity
ICCG: Solving for p: solution singularity
time step continuity errors : sum local = nan, global = nan, cumulative = nan
ExecutionTime = 1210.29 s
Could anyone give me some ideas of how to fix these problems?
Thanks in advance
jin
