NACA0012 with simpleFOAM
Old   November 27, 2007, 08:19
Default I'm working on an airfoil prof
Emanuele
nuovodna is on a distinguished road
I'm working on an airfoil profile NACA0012. I wrote my mesh in Gambit and then i imported it in OpenFOAM. I'm going to solver it with simpleFOAM (incompressible and steady flow, using kepsilon model) but the solution isn't accurate i think. At the angle of attack = 15° not stall and the total force on the profile is very low (i've calculated them using ssimpleFoam found in the board). I'd like to know:
1) what are the correct boundary condition on k and epsilon (in what way i give the correct k and epsilon fixed values on inlet patch and in internal field?)
2) do i have to use another model of turbulence?
Thanks in advantage
Emanuele
nuovodna is offline   Reply With Quote
Old   November 27, 2007, 10:15
Default I think, you must use freestre
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
I think, you must use freestream BC for infinity field, standard wall BC for walls on profile and inlet for inlet patch.
inlet: U - fixedValue, p - zeroGradient, k - fixedValue, epsilon - fixedValue
infinity field - U - freestream, p - freestreamPressure, k and epsilon - zeroGradient.
profile walls - U - fixedValue (0 0 0), p - zeroGradient, k and epsilon - zeroGradient
mkraposhin is offline   Reply With Quote
Old   November 27, 2007, 10:48
Default what are the fixed values of k
Emanuele
what are the fixed values of k and epsilon to setting? is there a mode to calculate them?
Old   November 27, 2007, 20:44
Default what kind of model of turbulen
Emanuele
what kind of model of turbulence is better??
and for the better what are the boundary condition on the k epsilon or another variable?
what is the better schemes to use?
Old   November 28, 2007, 02:44
Default For k/epsilon, I normally spec
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
For k/epsilon, I normally specify turb. intensity and the mixing length. I don't say that you have good values for these, but I find them a bit easier to visualize than the raw tke and dissipation.
The boundary conditions for 10% turbulence and 5mm length scale would look something like this:
// k
dimensions [ 0 2 -2 0 0 0 0 ];
internalField uniform 1;
inlet
type turbulentIntensityKineticEnergyInlet;
intensity 0.1;
value 1;
// epsilon
dimensions [ 0 2 -3 0 0 0 0 ];
internalField uniform 200;
inlet
type turbulentMixingLengthDissipationRateInlet;
mixingLength 0.005;
value uniform 200;
NB: The stability of your calculation can be greatly affected by the initialization of epsilon.
olesen is offline   Reply With Quote
Old   December 2, 2007, 09:31
Default the value on inlet patch of k
Emanuele
the value on inlet patch of k and epsilon affect very greatly the solution...also using komega model you can choose the initial values very well....in what way can i fix this initial values (of k epsilon and omega) to obtain the correct solutions??
Old   December 3, 2007, 04:52
Default Hello, what does "valu
Markus Rehm
markusrehm is on a distinguished road
what does
"value 1;"
in k and
"internalField uniform 200;"
in epsilon stand for? It is the same as internalField, why do we need it in the BC-description?
Regards Markus
markusrehm is offline   Reply With Quote
Old   May 19, 2010, 04:58
bephi is on a distinguished road
Hi at all,
i'd like to continue this thread because I have a lot of trouble with bounding k/epsilon although there are so many threads concerning this topic.
so far I know that the initialization of k and epsilon is very important to achieve a stable calculation.
but actually I don't really know what went wrong. I would like to simulate a flow throw a piston valve using the simpleFoam solver with the RNG k_epsilon model.
Here are my settings. Maybe you can take a look what should be changed to get a stable calculation:
p
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 476.2;
U
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0 0 -1);
    outlet
        type            zeroGradient;
k
internalField   uniform 0.0003;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0.0003;
    outlet
        type            zeroGradient;
epsilon
internalField   uniform 1.35e-4;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 1.35e-4;
    outlet
        type            zeroGradient;
nut
internalField   uniform 0.1;
boundaryField
    inlet
        type            freestream;
        freestreamValue uniform 0.1;
        value           uniform 0.1;
    outlet
        type            freestream;
        value           uniform 0.1;
controlDict
application             simpleFoam;
startFrom             startTime;
startTime            0;
stopAt                 endTime;
endTime                7.2e-2;
deltaT                 3e-6;
writeControl             timeStep;
writeInterval            1000;
purgeWrite            0;
writeFormat            ascii;
writePrecision            6;
writeCompression        uncompressed;
timeFormat            general;
timePrecision            6;
graphFormat            raw;
runTimeModifiable        yes;
fvSchemes
ddtSchemes
    default steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,R)      Gauss upwind;
    div(R)          Gauss linear;
    div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(DREff,R) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p;
fvSolution
solvers
    p PCG
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0.01;
    U PBiCG
        preconditioner   DILU;
        tolerance        1e-05;
        relTol           0.1;
    k PBiCG
        tolerance        1e-05;
        relTol           0.1;
    epsilon PBiCG
        tolerance        1e-05;
        relTol           0.1;
    R PBiCG
        tolerance        1e-05;
        relTol           0.1;
SIMPLE
    nNonOrthogonalCorrectors 1;
relaxationFactors
    p               0.3;
    U               0.7;
    k               0.05;
    epsilon         0.05;
    R               0.7;
If there is something else to change or improve in my settings please let me know! I'll be very thankful!
Regards!
bephi is offline   Reply With Quote
How to model VGs over a NACA0012 Franny Main CFD Forum 2 March 25, 2007 05:05
Simulation over a NACA0012 Jungleland6 CFX 4 October 30, 2006 03:48
HELP naca0012 maritozzo OpenFOAM Running, Solving & CFD 1 October 14, 2005 17:48
CD & CL on a NACA0012 wing Xwang FLUENT 7 March 26, 2004 14:42
NACA0012 exp.results muygun Main CFD Forum 7 November 11, 2002 17:41
