-   -   Single Rotating Frame with MRFSimpleFoam (http://www.cfd-online.com/Forums/openfoam-solving/58867-single-rotating-frame-mrfsimplefoam.html)
david May 16, 2008 11:08
Hi everybody! I'm trying to
Hi everybody!
I'm trying to simulate a modified version of the mixerVessel2D case with MRFSimpleFoam. The stator should rotate with the same angular velocity as the rotor. For this reason I assigned all the cells to the cellZone rotor by modifying blockMeshDict.m4. I also modified constant/MRFZones so that the patch stator is rotating too.
Unfortunately I'm getting pretty high velocities and I don't know why.
http://www.cfd-online.com/OpenFOAM_D...ges/1/7703.jpg
Here are the modified files:
http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif blockMeshDict.m4
http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif MRFZones
Is it possible at all to simulate a Single Rotating Frame with MRFSimpleFoam or did I make a mistake? Any help would be really appreciated.
Regards
David
david May 19, 2008 05:51
I forgot to say that I'm using
I forgot to say that I'm using a value of 314.157 for omega. The highest velocity should be around 31.5 m/s and not 60 m/s. Any ideas?
Thanks
David
david May 19, 2008 09:34
Ok, sorry guys. I found the pr
Ok, sorry guys. I found the problem. It was my mistake ;-)
dmoroian May 19, 2008 10:06
Hi David, I just tried a simi
Hi David,
I just tried a similar case with yours and it works (omega =104.72 rad/s; radius = 0.514 m -> v = 53 m/s):
http://www.cfd-online.com/OpenFOAM_D...ges/1/7725.jpg
Dragos
david May 20, 2008 08:21
Hi Dragos Thank you very mu
Hi Dragos
Thank you very much for helping me. Unfortunately I can't understand why it worked with your case while it didn't work with my case??
My problem was that I didn't set up the case correctly. I found two different solutions for my problem:
Solution 1:
- Assign all the cells to cellZone rotor in blockMeshDict.m4
- Move the faces from patch stator to patch rotor and delete patch stator in blockMeshDict.m4
Solution 2:
- Assign the rest of the cells to cellZone stator.
- Modify makeMesh and the dict-files so that all the operations are made for rotor & stator.
- Change MRFZones in the following way:
2
rotor
patches (rotor);
origin origin [0 1 0 0 0 0 0] (0 0 0);
axis axis [0 0 0 0 0 0 0] (0 0 1);
omega omega [0 0 -1 0 0 0 0] 314.159;
stator
patches (stator);
Regards
David
david May 20, 2008 09:58
Solution 1b: - Assign all the
Solution 1b:
1
rotor
patches (rotor stator);
dmoroian May 20, 2008 10:04
Hello David, From what I unde
Hello David,
From what I understand, you want to rotate everything, so you should assign all the cells to the rotor.
Basically, you are after a rotating rigid body solution.
Dragos
david May 22, 2008 04:25
Hi Dragos That is exactly w
Hi Dragos
That is exactly what I wanted to do. My intention was to play with a simple case to understand it. Now I'm trying to simulate a pump impeller.
Regards
David
