I started running a simulation
I started running a simulation using the foamJob command, with the correct solver, root and case, and a log file was created in the case folder. Now I am trying to run foamLog so that I can plot the residuals however every time I execute foamLog, with the correct root, case and log file, I get the message
foamLog: cannot read log log where the first log is the name of the log file. does anyone have a solution to this problem? Thanks in advance Liam |
Just type foamLog without any
Just type foamLog without any arguments and it will print out what it needs. You are probably missing the path to the log file.
Thanks for the reply.
my case
my case is called "flow", it is saved in my home folder "/home/liam" and the log file is called "log". I am executing foamLog /home/liam flow log do i need an extension on my log file like .txt or something like that? Liam |
Try foamLog /home/liam flow fl
Try foamLog /home/liam flow flow/log
It's working now
Thanks for
It's working now
Thanks for the help Liam |
Hi everybody
I have a probl
Hi everybody
I have a problem with foamLog. I think I miss some thing but i could'nt find it. I created file rasInterFoam.log in the backStepRSTML1 folder. I run the foamLog commad just in seen below. It reads rasInterFoam.log file and creates a .awk file and executes it. But i does'nt writes any thing in the logs folder. Thanks Onur [dundar@localhost rasInterFoam]$ foamLog . backStepRSTML1 backStepRSTML1/rasInterFoam.log Using: root : . case : backStepRSTML1 log : backStepRSTML1/rasInterFoam.log database : /home/dundar/OpenFOAM/OpenFOAM-1.4.1/bin/foamLog.db awk file : ./backStepRSTML1/logs/foamLog.awk files to : ./backStepRSTML1/logs Executing: awk -f ./backStepRSTML1/logs/foamLog.awk backStepRSTML1/rasInterFoam.log Generated XY files for: [dundar@localhost rasInterFoam]$ |
Hi everyone,
I experienced
Hi everyone,
I experienced a problem with foamLog. I've been using liftDrag to print the lift and drag coefficients into the log file and I do see them printed there according to the time steps. But when I run foamLog, it extracts everything else but not the drag and lift coefficients. How do I get it to extract the relevant data? Thanks Samuel |
Ok, I realized that Srinath ha
Ok, I realized that Srinath has posted before how to get foamLog to extract the lift and drag coefficients in another thread. Thanks once again
Hi guys
I have a similar problem with foamLog in OF 1.4. My simulation finished and no i want to plot residuals. Every time I try to execute foamLog nothing happens. Here is what I tried: [caelinux@localhost BLENDE]$ foamLog . home/caelinux/OpenFOAM/caelinux-1.4.1/run/BLENDE BLENDE BLENDE/simpleFoam foamLog - extracts xy files from Foam logs. Usage: foamLog [-n][-s] <root> <case> <log> extracts xy files from log foamLog -l <log> lists but does not extract foamLog -h for a help message Thanks blacy |
THX for reply. I thought that I gave it three arguments :confused: root: home/caelinux/OpenFOAM/caelinux-1.4.1/run/BLENDE case: BLENDE log: BLENDE/simpleFoam I`ll give pyfoam a try cause of some other interesting tools... |
Bernhard |
I`ll try but it will take a few weeks. If there are any problems I let you know...
I just enter the folder where my log is and type foamLog. Then there is an error Executing: awk -f ./logs/foamLog.awk log awk: ./logs/foamLog.awk:32: N-DODECANECnt=0 awk: ./logs/foamLog.awk:32: ^ syntax error awk: ./logs/foamLog.awk:33: N-DODECANEFinalResCnt=0 awk: ./logs/foamLog.awk:33: ^ syntax error awk: ./logs/foamLog.awk:34: N-DODECANEItersCnt=0 awk: ./logs/foamLog.awk:34: ^ syntax error and my created logs folder just contains, foam.awk. whats the problem? Thx |
| All times are GMT -4. The time now is 10:33. |
