Home > Forums > OpenFOAM Running, Solving & CFD
C question
Old   March 4, 2008, 05:59
Default Dragos, I did followed thr
  #21
kar
Kārlis Repsons
kar is on a distinguished road
Dragos,
I did followed through code, but did you read previous posts - the thing is: when I try to declare my own base and derived class with operator= in base class, operator= isn't accessible for object of class deriv if there is no forwarding in deriv class's declaration. Can't see such forwarding in class GeometricBoundaryField (and others) - can you help?
K.
kar is offline   Reply With Quote
Old   March 4, 2008, 09:59
Default Indeed you're right, and it wa
  #22
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Indeed you're right, and it was my mistake. I don't see why in your code it is possible to call int i = 10; d.se(i); but not int i = 10; d.operator=(10); nor int i = 10; d = i;
...promise to look into it!
Dragos
dmoroian is offline   Reply With Quote
Old   March 5, 2008, 08:47
Default Ok, I think I have an answer!
  #23
dmoroian's Avatar
Dragos
Among other free on-line c++ book, there is also Thinking in C++ by Bruce Eckel. It specifies, and I quote:
Except for the assignment operator, operators are automatically inherited into a derived class.
Which means that, you just picked an unfortunate example, trying to overload operator=. If instead of operator=, you would have chosen any other operator, like operator[], then everything would go smoothly.
I've just tried it, and it works!
I hope this is useful,
Dragos
Old   March 5, 2008, 08:59
Default Thank you! I'll take a look at
  #24
kar
Kārlis Repsons
Thank you! I'll take a look at that book
Old   May 19, 2008, 13:27
Default Hmm, may I ask about virtual f
  #25
kar
Kārlis Repsons
Hmm, may I ask about virtual functions and inheritance?
#include <iostream>
using namespace std;
class base1
public:
bool use(bool y) {return x(y);}
virtual bool x(bool y) = 0;
class base2
public:
bool x(bool y) {return !y;}
class deriv:
public base1, public base2
// whatever
int main( int c, char ** a)
deriv d;
if (!d.use(1)) cout << "yes";
return 1;
But it is "no", because compiler output is:
virtinh.cpp: In function 'int main(int, char**)':
virtinh.cpp:26: error: cannot declare variable 'd' to be of abstract type 'deriv'
virtinh.cpp:20: note: because the following virtual functions are pure within 'deriv':
virtinh.cpp:9: note: virtual bool base1::x(bool)
So is it impossible to "merge" an abstract class with definitions of virtual functions, that reside in another base class similarly to example below?
Old   May 19, 2008, 19:51
Default may be the pure virtual functi
  #26
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
may be the pure virtual function "virtual bool x(bool y) = 0; " in class "base1" should be defined definitely.
Su Junwei
su_junwei is offline   Reply With Quote
Old   May 20, 2008, 06:05
Default That is a whole point of my qu
  #27
kar
Kārlis Repsons
That is a whole point of my question, that virtual bool x(bool y) = 0; and I want it to be called from use(..) through deriv d!
Thread Tools
Trackbacks are On
Question concerning VOF Flora FLUENT 2 July 9, 2007 09:50
question about LES gino briganti FLUENT 3 June 27, 2005 06:05
A question zhhuang CD-adapco 0 April 29, 2003 01:44
The question about Y+ rambol CFX 2 November 7, 2002 10:40
Another UDF question Christian FLUENT 7 July 23, 2002 04:19
