Home > Forums > OpenFOAM Running, Solving & CFD
Compressible drag
Old   May 19, 2008, 08:26
Default Hi all, I am solving 3D air
Ryan Middleton
ryan_m is on a distinguished road
Hi all,
I am solving 3D airfoils (NACA 0016 @ 0 degrees) using rhoSimpleFoam. I am comparing different meshes. So far I have compared a constant surface mesh with a mesh refined at the trailing and leading edges. When I run liftDrag, i get a higher drag co-efficient for the mesh that is refined.
My friend did the same comparison using an incompressible solver in fluent. He found the refined mesh gave a lower drag co-efficient as it better resolved the forward facing pressure at the leading edge of the airfoil (which seems to make sense). My question is this:
Does anyone have any ideas as to why the results are opposite in the compressible solver? The two domains are a slightly different size, could this have an effect (although both domains should be sufficiently large)?
Thanks very much for any thoughts.
ryan_m is offline   Reply With Quote
Thread Tools
Trackbacks are On
Pressure drag, friction drag and total drag? Cheng CFX 4 December 2, 2006 23:19
compressible newposter Main CFD Forum 0 September 10, 2006 03:49
drag and lift coefficient of compressible cylinder Bin Li Main CFD Forum 1 March 7, 2004 10:49
compressible John Main CFD Forum 1 April 6, 2003 12:35
External Flow-compressible flow solver-lift/drag Tom Brown Main CFD Forum 7 December 29, 2000 14:41
