August 14, 2007, 11:23 |
I have been using the tutorial
Eric Moore
Rep Power: 17 |
I have been using the tutorials to become familiar with OpenFOAM and have been trying to recreate a cfdesign "turbulent flow over heated cylinder" case to compare different cfd packages. I know how to use FoamX, paraview etc, but my experience with flow is pretty minimal... I'm mostly the computer guy that's trying to get it to work.
I've created a satisfactory 2d (3d in foam but 2d for my purposes) mesh: it's a pipe cut in half lengthwise, with half a circle cut out where the "heated cylinder" would is. I therefore have six patches: left (needs to be a velocity inlet at 50 m/s), right (pressure outlet at 0 pa) down and cylinder (symmetryplanes), and up (wallFunctions). I could not find an explicit "velocity inlet" in FoamX for the left side. From the example "cavity" case in the turbFoam directory I decided to make it a "wallFunction" and defined 50 for the x coordinate. I calculated k and epsilon values for my particular case and input them in FoamX. They are 9.375 and 188.7 respectively. I think the delta_t required for the courant number is something like 0.003 s. What I'm having problems with is the p field file. I get the following error: Create mesh for time = 0 Reading field p --> FOAM FATAL IO ERROR : attempt to read beyond EOF I'm guessing that it would try to read beyond the end of file if it wasn't finding everything it needed, but that's a pretty feeble guess. I tried to compare the cavity p and my file for differences, and the only thing I see is that I defined a p=0 for the right patch, all of the cavity patches are zeroGradient, and my internalField is nonuniform, whereas the cavity one is set to 0. I'm going to append my p file to the end of this message. Any help at all would be greatly appreciated. /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ // Field Dictionary FoamFile { version 2.0; format ascii; root "/home/flowloop/OpenFOAM/flowloop-1.4/run/tutorials/turbFoam"; case "2.20"; instance "0"; local ""; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField nonuniform; boundaryField { down { type symmetryPlane; } right { type fixedValue; value uniform 0; } up { type zeroGradient; } left { type zeroGradient; } cylinder { type symmetryPlane; } defaultFaces { type empty; } } // ************************************************** *********************** // |
August 14, 2007, 11:24 |
In the previous message, I lis
Eric Moore
Rep Power: 17 |
In the previous message, I listed 5/6 patches. My 6th patches are the top and bottom of the 3d mesh, and I have set them to empty. I guess you can see that in the p file anyway, but just to clarify .
August 14, 2007, 11:48 |
This is wrong:
internalFiel
Alberto Passalacqua
Rep Power: 36 |
This is wrong:
internalField nonuniform; Try with something like: internalField uniform 0.0; Bye, Alberto
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
August 14, 2007, 13:42 |
That fixed my error, thank you
Eric Moore
Rep Power: 17 |
That fixed my error, thank you! Sadly I have another error, and I can't make any sense of it. This may be the result of me cloning the cavity case, then using a completely different mesh. I read somewhere about compiling solvers... would I need to do that for my situation? Thanks, Eric.
Selecting incompressible transport model Newtonian Selecting turbulence model kEpsilon #0 Foam::error::printStack(Foam:stream&) #1 Foam::sigFpe::sigFpeHandler(int) #2 Uninterpreted: [0xffffe420] #3 Foam::turbulenceModels::kEpsilon::kEpsilon(Foam::G eometricField<foam::vector<dou ble>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::transportModel&) #4 Foam::turbulenceModel::adddictionaryConstructorToT able<foam::turbulencemodels::k epsilon>::New(Foam::GeometricField<foam::vector<do uble>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::transportModel&) #5 Foam::turbulenceModel::New(Foam::GeometricField<fo am::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::transportModel&) #6 main #7 __libc_start_main #8 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122 ^[[5~^[OH^[[5~^[[5~ |
August 14, 2007, 13:57 |
You're probably initializing k
Alberto Passalacqua
Rep Power: 36 |
You're probably initializing k and/or eps to zero. Check the value specified in k and epsilon dictionaries for the internalField.
A.
August 14, 2007, 14:34 |
I've got k set to 9.375 and ep
Eric Moore
Rep Power: 17 |
I've got k set to 9.375 and eps set to 188.7. Do I need to set R and Nut as well? I left them blank.
August 14, 2007, 14:44 |
For R:
internalField unif
Alberto Passalacqua
Rep Power: 36 |
For R:
internalField uniform (0 0 0 0 0 0 0 0 0); For nuTilda: internalField uniform 0; Give a look to the turbFoam tutorial.
August 14, 2007, 15:00 |
I made sure those values were
Eric Moore
Rep Power: 17 |
I made sure those values were set, but I still get the message.
August 14, 2007, 15:16 |
Please post the case, so we ca
#9 |
Alberto Passalacqua
Rep Power: 36 |
Please post the case, so we can give it a look.
Regards, A.
August 14, 2007, 15:49 |
Here's the entire thing. I don
#10 |
Eric Moore
Rep Power: 17 |
Here's the entire thing. I don't know that the mesh has enough resolution, but I'm mainly trying to get the solver to run right now.
http://web.utk.edu/~emoore20/cyl2.tar.gz Thanks again, Eric |
August 14, 2007, 16:09 |
Here are the issues:
- In t
#11 |
Alberto Passalacqua
Rep Power: 36 |
- In transportProperties: nu = 0. - Empty schemes field in fvSchemes: divSchemes { default none; div(phi,U) Gauss <>; div(phi,k) Gauss <>; div(phi,epsilon) Gauss <>; div(phi,R) Gauss <>; div(R) Gauss linear; div(phi,nuTilda) Gauss <>; div((nuEff*dev(grad(U).T()))) Gauss linear; } Plus all boundary conditions have zero velocity. I fixed these settings, and now the code runs, but of course you're solving for nothing, being U = 0. correctedCase.tar.gz Regards, Alberto
August 14, 2007, 16:14 |
Note: I removed the mesh to cr
#12 |
Alberto Passalacqua
Rep Power: 36 |
Note: I removed the mesh to create a small file.
A.
August 15, 2007, 14:45 |
Thanks for looking at the code
#13 |
Eric Moore
Rep Power: 17 |
Thanks for looking at the code, now I can at least get some iterations done! However, I set left to [50 0 0] in the U field and the solver errors after completing t=0.03 after six iterations. When I view the results in parafoam, t=0.3 and even t=0 have the U field at infinity at all points and the p field is NaN at all points. Here's the error, any ideas?
#0 Foam::error::printStack(Foam:stream&) #1 Foam::sigFpe::sigFpeHandler(int) #2 Uninterpreted: [0xffffe420] #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const #4 Foam::fvMatrix<double>::solve(Foam::Istream&) #5 Foam::lduMatrix::solverPerformance Foam::solve<double>(Foam::tmp<foam::fvmatrix<doubl e> > const&) #6 Foam::turbulenceModels::kEpsilon::correct() #7 main #8 __libc_start_main #9 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122 |
August 15, 2007, 14:59 |
I think it may be the courant
#14 |
Eric Moore
Rep Power: 17 |
I think it may be the courant number... isn't it supposed to be under 1?
Time = 0.03 Courant Number mean: 1.07121e+48 max: 1.51093e+51 DILUPBiCG: Solving for Ux, Initial residual = 7.37701e-06, Final residual = 7.37701e-06, No Iterations 0 DILUPBiCG: Solving for Uy, Initial residual = 2.56253e-06, Final residual = 2.56253e-06, No Iterations 0 DICPCG: Solving for p, Initial residual = 1, Final residual = 5.79649e-07, No Iterations 104 time step continuity errors : sum local = 5.76439e+60, global = 3.20979e+58, cumulative = 3.20979e+58 DICPCG: Solving for p, Initial residual = 3.18555e-12, Final residual = 3.18555e-12, No Iterations 0 time step continuity errors : sum local = 5.19003e+167, global = -1.3427e+151, cumulative = -1.3427e+151 |
May 18, 2008, 23:45 |
Eric......... What have you do
#15 |
Mohd Yousuf
Rep Power: 17 |
Eric......... What have you done to decrease the courant no. in the above case?
Display Modes | |
Turbfoam error | danie | OpenFOAM Running, Solving & CFD | 2 | July 30, 2008 07:45 |
Error message-Floating point error | Vaibhav | FLUENT | 3 | December 7, 2007 05:38 |
Error turbFoam | jackdaniels83 | OpenFOAM Running, Solving & CFD | 11 | June 27, 2007 14:22 |
ERROR MESSAGE: line 1: parse error | Lourival | FLUENT | 1 | February 18, 2006 01:35 |
Gambit 2.0 - Error Message (ACIS ERROR 1200) | James | FLUENT | 1 | May 14, 2003 08:13 |
