Attempt to understand icoFoam transientSimpleFoam on cavity testcase
Old   April 28, 2008, 09:06
Default Dear All Greetings. Conc
jaswi is on a distinguished road
Dear All
Greetings.
Conceptually both SIMPLE and PISO formulations can be used to solve problems of transient nature. In the list of OpenFOAM solvers
--> icoFoam is the transient solver for incompressible, laminar flow of Newtonian fluids.
--> transientSimpleFoam is the transient solver for incompressible, turbulent flow of on-Newtonian
fluids.
In principle if one modifies the transientSimpleFoam solver by removing the turbulence calculation part then the two solvers should deliver the same result.
As far my as understanding goes the transientSimpleFoam shall take more time to converge as it uses under-relaxation.
The original icoFoam solver in its unmodified form is:
int main(int argc, char *argv[])
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
# include "createFields.H"
# include "initContinuityErrs.H"
Info<< "\nStarting time loop\n" << endl;
for (runTime++; !runTime.end(); runTime++)
Info<< "Time = " << runTime.timeName() << nl << endl;
# include "readPISOControls.H"
# include "CourantNo.H"
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvm::laplacian(nu, U)
solve(UEqn == -fvc::grad(p));
// --- PISO loop
for (int corr=0; corr<nCorr; corr++)
volScalarField rUA = 1.0/UEqn.A();
U = rUA*UEqn.H();
phi = (fvc::interpolate(U) & mesh.Sf())
+ fvc::ddtPhiCorr(rUA, U, phi);
adjustPhi(phi, U, p);
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix pEqn
fvm::laplacian(rUA, p) == fvc::div(phi)
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve();
if (nonOrth == nNonOrthCorr)
phi -= pEqn.flux();
# include "continuityErrs.H"
U -= rUA*fvc::grad(p);
U.correctBoundaryConditions();
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return(0);
Now here is the transientSimpleFoam with the changes. I have just removed the turbulence calculation part and the fvMatrixMatrix UEqn is same as in icoFoam. Here is the changed version:
// Pressure-velocity SIMPLE corrector loop
// Momentum predictor
tmp<fvvectormatrix> UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
+ fvm::laplacian(nu, U)
UEqn().relax();
solve(UEqn() == -fvc::grad(p));
p.boundaryField().updateCoeffs();
volScalarField rUA = 1.0/UEqn().A();
U = rUA*UEqn().H();
UEqn.clear();
phi = fvc::interpolate(U) & mesh.Sf();
// Store pressure for under-relaxation
p.storePrevIter();
// Non-orthogonal pressure corrector loop
fvScalarMatrix pEqn
pEqn.solve();
phi -= pEqn.flux();
// Explicitly relax pressure for momentum corrector
p.relax();
// Momentum corrector
runTime.write();
<< " s\n\n" << endl;
return(0);
I ran both solvers on the cavity with same settings in the controlDict, fvSchemes, fvSolution. the fvSolution has the subDict settings for both algorithms:
PISO
nCorrectors 2;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
// Relaxation factors are used for transient SIMPLE
relaxationFactors
p 0.5;
U 0.8;
The results I get are completely different. I am posting here the pressure and velocity fields at t=0.5 for both solvers.
IcoFoam results (all the settings are standard by which I mean the settings given in the UserGuide for the lid driven cavity tutorial)
transientSimpleFoam results
Note the difference in the direction of velocity vectors
The difference in the results could be due to several reason. All I am trying here is to understand how to tune these two solvers which are solving the same physics but using different pressure-velocity coupling.
Any inputs will be helpful
With best regards
Jaswi
jaswi is offline   Reply With Quote
Old   April 28, 2008, 10:47
Default Hi Jaswi Looking at the low
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Jaswi
Looking at the lowermost plot, which I suspect is the velocity field, I cannot see any boundary, where the velocity is not zero!?!
Thus could it be that you have forgotten to set the boundary condition on U?
Best regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   April 28, 2008, 19:04
Default Hi Niels Thank for the comm
Hi Niels
Thank for the comment.
Please take a notice of the comments in the post. I have mentioned above that the first two pictures, i.e. pressure and velocity plots are for the led driven cavity using icoFOAM
Now icoFoam uses PISO pressure-velocity coupling algorithm. There is also another solver called transientSimpleFoam which uses the SIMPLE pressure-velocity coupling algorithm . The last two picture are pressure and velocity for the same led driven cavity but now using the modifeid transientSimpleFoam given above in the post.
I again emphasize on the fact that the two solvers
differing only in their pressure-velocity coupling algorithm were run on the same case i.e. lid driven cavity.
Hope that clears the doubt. I am waiting eagerly for the comments :-)
With Regards
Jaswi
Old   April 29, 2008, 04:37
Default Any reason you're adding and n
Mattijs Janssens
Any reason you're adding and not subtracting the viscous contribution in your UEqn?
Old   April 29, 2008, 05:40
Default Hi Mattijs Thanks a lot for
Hi Mattijs
Thanks a lot for pointing out that mistake.
I am really sorry for not cross checking my stuff and creating unnecessary trouble.
With that correction , both SIMPLE and PISO deliver identical results , at first glance at least.
I am thankful to you for help. If possible please point me to necessary routines on how I can compare the error for the two solvers and make a quantitative analysis. Just some pointers.
In that way I can do the quantitative analysis for these two pres-velocity algorithms solving the same physical model and put the results on Wiki. It might be useful to somebody trying to understand the solution approach
With Best Regards
Jaswi
Old   April 29, 2008, 05:41
Default Hi Nice spotting Mattjis...
ngj
Hi
That could easily explain the lowermost picture, because the change in sign makes the diffusion term into an energy source. Thus if you put on a scale bar, you will probably experience that the maximum velocities in your transientSimpleFoam case is significantly larger than the lid velocity.
- Niels
Old   July 10, 2009, 05:01
Bernard Esterhuyse
bernarde is on a distinguished road
Hi
I'm looking for the transientSimpleFoam solver, but I cannot find it in the 1.5 distribution. Is there another location for it?
Thanks
bernarde is offline   Reply With Quote
FOAM FATAL IO ERROR attempt to read beyond EOF unoder OpenFOAM Running, Solving & CFD 10 April 16, 2024 03:03
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
TransientSimpleFoam skabilan OpenFOAM Running, Solving & CFD 2 June 4, 2008 20:39
Validation and Testcase Araz Main CFD Forum 0 August 5, 2004 08:36
ERCOFTAC testcase # 11 Aldo Bonfiglioli Main CFD Forum 0 September 11, 1998 09:02
