Please help me specify the Desity and viscosity for each cell
Old   December 4, 2005, 21:20
Default Dear all: I am eager to you
Guoxiang
liugx212 is on a distinguished road
Dear all:
I am eager to your help because I am a new learner in openfoam. I have a trouble that how to control the desity and viscosity for each cell for several days. So could you please give some advice and help?
my try to give code as:
scalarField& nuInternal = nu.internalField();
const scalarfield& nuInternal = nu.internalField();
forAll (nuInternal, celli)
Thanks deeply,
Guoxiang
liugx212 is offline   Reply With Quote
Old   December 4, 2005, 21:32
Default you can make: forAll(nu,cellI
olivier Petit
olivier is on a distinguished road
you can make:
forAll(nu,cellI)
nu[cellI]=...
so you can change the value of nu in each cell.
enjoy
olivier is offline   Reply With Quote
Old   December 4, 2005, 21:54
Default Dear olivier baily: Thanks
Guoxiang
Dear olivier baily:
Thanks for your help!
Yes, I have tried just now. But there are some errors as follows. Also, I think the "rho", "E" are specified as the same way, right?
Again, Thanks and have great day.
Guoxiang
errors:
stressedFoam.C:115: error: 'scalarField' was not declared in this scope
stressedFoam.C:115: error: 'nuInternal' was not declared in this scope
stressedFoam.C:115: error: 'struct Foam::dimensionedScalar' has no member named 'internalField'
stressedFoam.C:116: error: expected initializer before '&' token
115: scalarField& nuInternal = nu.internalField();
116: const scalarfield& nuInternal = nu.internalField();
Old   December 4, 2005, 22:49
Default You can't use internalField f
olivier Petit
You can't use internalField function to a scalarField but you can use it with the volScalarField..
for each sacalarField you can change the value in the cell with the same way.
olivier
Old   December 5, 2005, 01:35
Default Dear olivier baily: Sorry t
Guoxiang
Dear olivier baily:
Sorry to bore you again. I really a new comer so I have some questions. please do not mind me.
As you said, I modified as:
115: const volScalarField& nuInternal = nu.internalField();
116: forAll (nuInternal, celli)
117: {
118: nuInternal[celli] = 1;
119: }
But I was told as follows:
115: struct Foam::dimensionedScalar has no member named internalField
118: error: assignment of read-only location
Could you please give help again.
Thanks and sorry to bore you.
Guoxiang
Old   December 5, 2005, 05:13
Default Try (haven't tried it myself):
Mattijs Janssens
Old   December 5, 2005, 10:20
Default Dear Mattijs Janssens: Than
Guoxiang
Thanks for your help. There was said that:
for this line:
I am findind where is error. Could you please give help again.
Thanks deeply,
Guoxiang
Old   December 5, 2005, 11:30
Default Dear all: I am eager to get
Guoxiang
Dear all:
I am eager to get your help.
Please help me see the code again since I have no ideas to debug this.
// set the nu for each cell
116: volScalarField& nuInternal = nu.internalField();
if (componentValue[celli] > 0)
nuInternal[celli] = 0.3;
else nuInternal[celli] = 0.1;
// set the rho for each cell
125: volScalarField& rhoInternal = rho.internalField();
forAll (rhoInternal, celli)
rhoInternal[celli] = 2000000;
else rhoInternal[celli] = 20000;
// set the E for each cell
134: volScalarField& EInternal = E.internalField();
forAll (EInternal, celli)
EInternal[celli] = 7854;
else EInternal[celli] = 1000;
Error as:
stressedFoam.C:116: error: 'struct Foam::dimensionedScalar' has no member named 'internalField'
stressedFoam.C:125: error: 'struct Foam::dimensionedScalar' has no member named 'internalField'
stressedFoam.C:134: error: 'E' was not declared in this scope
stressedFoam.C:134: error: '<typeprefixerror>E' previously declared here
Thanks deeply,
Guoxiang
Old   December 5, 2005, 15:28
Default Daer All: Please give piece
Guoxiang
Daer All:
Please give pieces of advice and help.
Thanks,
Guoxiang
Old   December 8, 2005, 11:58
Default Dear all: I still not get s
Guoxiang
Dear all:
I still not get sucess. Could you please give some advice and help.
Thanks a lot.
Guoxiang
Old   December 9, 2005, 05:11
Default dear Guoxiang, i am sorry t
  #11
VVqf
vvqf is on a distinguished road
dear Guoxiang,
i am sorry to say it, but you do need do more programming. Check your src file, whether all needed .inc files are included. go into the error, locate and fix it.
if you don't get answer anymore, either it's too basic, or too difficult that nobody can answer.
vvqf is offline   Reply With Quote
Old   April 29, 2008, 04:42
Default The advice above, I've used th
  #12
Christian Andersen
christian_andersen is on a distinguished road
The advice above, I've used this for a Eddy-Break-up model for combustion.
It works fine when run on 1 CPU, but when I try to run it parallel - it fails!
Any advice? Does anyone know what the problem is?
Best
Christian Andersen
christian_andersen is offline   Reply With Quote
turbulent viscosity limited to viscosity ratio of Hua FLUENT 7 September 27, 2019 06:42
turbulent viscosity limited to viscosity ratio... frank FLUENT 19 December 15, 2015 22:54
"turbulent viscosity limited to viscosity ratio" olivier FLUENT 11 October 10, 2015 05:49
turbulent viscosity limited to viscosity ratio Elizabeth FLUENT 13 December 16, 2014 08:57
Turbulent viscosity Limited to viscosity ratio Adrian FLUENT 12 September 21, 2011 04:22
