-   -   Tutorials 22 error (http://www.cfd-online.com/Forums/openfoam-solving/58928-tutorials-22-error.html)
ztdep April 26, 2008 02:10
Dear friends: when i run t
Dear friends:
when i run the tutorials 2.2, i met the following error, my openfoam is 1.4.1
--> FOAM FATAL IO ERROR : expected 'true' or 'false', found yes
file: /root/OpenFOAM/root-1.4.1/run/tutorials/solidDisplacementFoam/plateHole/system/f vSolution::D::scaleCorrection at line 41.
From function operator>>(Istream&, bool&)
in file primitives/bool/boolIO.C at line 72.
FOAM exiting
after i modify the yes to true and no to false, then erverything is ok
but the fvSolution file is generated by the foamX, it is not written by myself, so would you please tell me what is the problem.
Regards
mkraposhin April 26, 2008 05:37
You can modify solver or FoamX
You can modify solver or FoamX.
modifying of solver is easy (just look for sources and find where solver controls are read). But, on my opinion, it is better to modify FoamX configs
First of all, look in to the file
OpenFOAM/OpenFOAM-1.4/applications/solvers/stressAnalysis/solidDisplacementFoam/ FoamX/fvSolution.cfg - here you will find files, that FoamX uses as configuration for GUI dialogs
No, go to file
/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/FoamX/types/Switch.cfg
and modify it as proposed. for example, file was:
Switch
type word;
iconURL "/FoamX/icons/small/maths/Switch.gif";
valueList
yes
no
SwitchOnOff
type word;
valueList
on
off
after modifying:
Switch
type word;
valueList
yes
no
SwitchTrueFalse
type word;
valueList
true
false
SwitchOnOff
type word;
valueList
on
off
now, go to file
/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/FoamX/entries/Switch/compactNormalStre ss.cfg
and modify <type> to new introduced type <switchtruefalse>
and <default> to <true>
it is good practice to backup old files (if something goes wrong)
good luck!
P.S.
may be you need to add some another changes in FoamX configs...
P.P.S.
command line is much better!
