Home > Forums > OpenFOAM Running, Solving & CFD
Error message what does it mean
Old   April 24, 2008, 06:01
Default Hi, I'm starting to use the
cfdphil
cfdphil is on a distinguished road
I'm starting to use the rhoSimpleFoam solver and variations of this. I can't get the solution start as it comes up with an error after selecting the turbulence model. Does anyone know what this means:
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package hThermo<puremixture<consttransport<speciethermo<hc onstthermo<perfectgas>>>>>
Reading field U
Creating turbulence model
Selecting turbulence model realizableKE
#0 Foam::error::printStack(Foam:stream&) in "/home/phil/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/phil/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/tls/libc.so.6"
#3 Foam::compressible::turbulenceModels::realizableKE ::realizableKE(Foam::Geometric Field<double,> const&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::basicThermo&) in "/home/phil/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libcompressibleTurbulenc eModels.so"
#4 Foam::compressible::turbulenceModel::adddictionary ConstructorToTable<foam::compr essible::turbulencemodels::realizableke>::New(Foam ::GeometricField<double,> const&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::basicThermo&) in "/home/phil/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libcompressibleTurbulenc eModels.so"
#5 Foam::compressible::turbulenceModel::New(Foam::Geo metricField<double,> const&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::basicThermo&) in "/home/phil/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libcompressibleTurbulenc eModels.so"
#6 main in "/home/phil/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/rhoSimpleFo am"
#7 __libc_start_main in "/lib64/tls/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/home/phil/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/rhoSimpleFo am"
Thanks,
Phil
cfdphil is offline   Reply With Quote
Old   April 24, 2008, 09:40
Default It's ok, found the problem,
cfdphil
initial value for p set to 0 !!
Thread Tools
Trackbacks are On
Error message-Floating point error Vaibhav FLUENT 3 December 7, 2007 06:38
ERROR MESSAGE: line 1: parse error Lourival FLUENT 1 February 18, 2006 02:35
help on error message zwdi FLUENT 1 January 10, 2004 23:58
Error message RM FLUENT 2 January 8, 2004 07:05
Gambit 2.0 - Error Message (ACIS ERROR 1200) James FLUENT 1 May 14, 2003 08:13
