-   -   POTENTIALFOAM ERROR for a naca profile (http://www.cfd-online.com/Forums/openfoam-solving/58942-potentialfoam-error-naca-profile.html)
dinonettis April 10, 2008 09:44
Hi everybody, I'm a new use
Hi everybody,
I'm a new user of openfoam and I'm trying to analyse a naca profile with potentialfoam. Although I'm quite sure concerning the boundary conditions these are the results that I get on a C-grid:
The boundary conditions are the following:
-domain contour: freestream (U=239.6 m/s p=26624 Pa)
-lateral side:empty (2D analysis)
- wing: wall
and this is the 0/U file:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (239.6 0 0);
boundaryField
defaultFaces
type empty;
lateral_side1
type empty;
lateral_side2
type empty;
outlet
type inletOutlet;
inletValue uniform (239.6 0 0);
value uniform (239.6 0 0);
wing
type fixedValue;
value uniform (0 0 0);
freestream
type inletOutlet;
I hope somebody can help me.
Thank you very much
dino
ngj April 10, 2008 10:09
Hi I could not download yo
Hi
I could not download your attached file, but anyway:
PotentialFoam solves the potential flow equations, but you are specifying a no-slip condition on the wing. This will include shear into the solution, which violate the assumption of irrotational flow.
Thus try to change the boundary condition at the wing to a "type slip" and see what happens.
Best regards and enjoy OFhttp://www.cfd-online.com/OpenFOAM_D...part/happy.gif
- Niels
dinonettis April 17, 2008 07:08
sorry but I did not realize th
sorry but I did not realize the images did not appear on the forum. Anyway now I hope I'll be able to show you the results:
http://www.cfd-online.com/OpenFOAM_D...your_image.gif
dinonettis April 17, 2008 07:12
http://www.cfd-online.com/OpenFOAM_D...ges/1/7378.jpg
dinonettis April 17, 2008 07:26
As you can see in the previous
As you can see in the previous image it is strange that the velocity around the wing (and in the whole domain) is equal to 0, whilst it should be 239.6 m/s according to the boundary condition! Moreover there is only a little flow perturbation on the trailing edge, but the velovity increase very much inside that!!
Finally this is another view of the whole domain (C-grid) in terms of streamlines, quite strange as well:
http://www.cfd-online.com/OpenFOAM_D...ges/1/7380.jpg
dinonettis April 18, 2008 06:36
hi niels, I've just tried t
hi niels,
I've just tried to follow your advice, substituting the wall with the slip condition on the wing. Unfortunately I get more or less the same results (both in terms of U range and streamlines). What do you think about that??
ngj April 21, 2008 04:02
Hi Leonardo Sorry for not a
Hi Leonardo
Sorry for not answering before, but here in Denmark we have a nice think called "big-prayer day", which is a holiday. A king some years back was annoyed by all the religious holidays scattered all over the year, so they were collapsed into one.
It does look strange indeed. I took a closer look on your boundary conditions, and I am not sure if you are allowed to use empty in two dimensions when solving a 2-dimensional flow!?! I would set the upper and lower boundary to symmetryPlane.
You could try to test your setup on a more simple geometry, such as a cylinder and see if you get the correct analytical solution.
Best regards,
Niels
darioth September 9, 2010 10:59
Hello Leonardo!
I am trying with potentialFoam with a 0015 and I have the same problem.
In the trailing edge, the velocity increase a little bit (like 70% than the free flow) but the rest of the flow field seem to be right, although this perturbation in the t.e. affects the values (not the distribution) of the velocity field.
Did you fix your problem?
Any tip will be usefull.
Best regards!!!
