January 28, 2022, 08:53 |
Error: Cannot find patchField entry
Rep Power: 7 |
i'm trying to run a 3D simulation with meshing with snappyHexMesh. In order to get a better wall meshing, i have define a plate to refine this surface. But as i run the solver, it told me that it cannot find the patchField "plate" (which i named in the snappyHexMeshDict). So the question is: do i need to define a BC for the "plate"? --> FOAM FATAL IO ERROR: (openfoam-2106 patch=211215) [1] Cannot find patchField entry for plate [1] [1] file: /home/nmeng/Schreibtisch/pod/processor1/0/p.boundaryField at line 11 to 50. [1] [1] From void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] [1] in file /builddir/build/BUILD/OpenFOAM-v2106/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 172. [1] FOAM parallel run exiting |
[snappyHexMesh] Cannot find patchField entry for *** | mbox97 | OpenFOAM Meshing & Mesh Conversion | 2 | November 25, 2021 10:06 |
Cannot find patchField entry for InletWall | range_rover | OpenFOAM Running, Solving & CFD | 5 | November 18, 2020 21:21 |
Parallel snappyHexMesh problem: Cannot find patchField entry for procBoundary2to7 | hconel | OpenFOAM Pre-Processing | 0 | October 5, 2018 17:22 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 06:32 |
