Adding source term to u eq
Like Tree15Likes
Old   March 14, 2008, 03:24
Default hi everybody, me again with a
robert maduta
roberthino is on a distinguished road
hi everybody, me again with a problem :-)
i now try to run my rans channel flow with cyclic boundary conditions, therefor i have to ad an extra term to the u eq in simpleFoam.C to keep a constant pressure gradient along the channel.
i really dont have a clue how to modify the u eq. i tried to do it like this:
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
+ 0.018
where 0.018 is the constant. this isnt working and it isnt compiling. maybe someone can help and tell me how to exactly implement the term.
thx
greetings robert
roberthino is offline   Reply With Quote
Old   March 14, 2008, 05:50
Default hi, 0.018 is a scalar not a
Stephan Gerber
stephan is on a distinguished road
hi,
0.018 is a scalar not an vector while U is a vector.
try to put the 0.018 as a component of a vector - this should work.
stephan
stephan is offline   Reply With Quote
Old   March 14, 2008, 08:56
Default You must add volVectorField wi
Marhamat Zeinali
marhamat is on a distinguished road
You must add volVectorField with correct dimension
marhamat is offline   Reply With Quote
Old   March 14, 2008, 14:22
Default is there an example where i ca
robert maduta
is there an example where i can have a look in the code where a constant term is added? do i only have to add the term + volVectorField(0.018, 0, 0)?
Old   March 14, 2008, 17:17
Default Hello Robert, you can add i
Alberto Passalacqua
Hello Robert,
you can add it exactly as g (gravity) is added.
For sake of simplicity of use, just add the vector you want to add to the momentum equation to your transportProperties dictionary (check dimensions):
myVector myVector [0 1 -1 0 0 0 0] (0.018 0 0);
then read it in createFields.H after the dictionary declaration:
dimensionedVector myVector
transportProperties.lookup("myVector")
and then add it to the equation ( ... + myVector).
Regards,
Alberto
Alberto Passalacqua
Old   March 14, 2008, 17:18
Default I mean you must define new va
Marhamat Zeinali
I mean you must define new variable as a volVectorField with correct dimension.
>such as:
volVectorField NSconstant=fvm::ddt(U);
forAll(mesh.C(),i)
NSconstant[i]=(0.018,0,0);
>then
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
+ NSconstant
songwukong and Luttappy like this.
Old   March 14, 2008, 22:46
Default You're right. Just shorter:
Alberto Passalacqua
volScalarField myVectorField("myVectorField", myVector & mesh.C());
Regards,
Alberto
Luttappy likes this.
Alberto Passalacqua
Old   March 15, 2008, 00:36
Default Thank's Alberto I prefere you
Marhamat Zeinali
Thank's Alberto
I prefere your method too.
Old   March 15, 2008, 08:02
Default well since my knowledge in c++
robert maduta
well since my knowledge in c++ is very very small i try to do it the first way described by alberto. as i understodd there has to be a file (transportproperties) where i first have to define this 0.018. then i have to ad it in the createfields so that the incompressible solver can read it. then i can finally ad the term in the momentum equation. well i managed to change the createfields the proper way and also put in the term in the momentum eq. but i cant find the transportProperties file where i have to ad
maybe you can help me out?
Old   March 15, 2008, 09:11
Default hi, go to the tutorials-dir
Stephan Gerber
hi,
go to the tutorials-dir in one of the cases from settlingFoam - there is a file called actually "environmentalProperties". just give the file a new name.
regards
stephan
Old   March 15, 2008, 09:35
Default Robert, I wrote a tutorial
  #11
Michael Jaworski
mike_jaworski is on a distinguished road
Robert,
I wrote a tutorial on adding a scalar transport equation and modifying the transportProperties dictionary (and how to read these things in openFOAM). It's on the wiki and maybe you can use it to help write your solver:
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
Good luck,
Mike J.
mike_jaworski is offline   Reply With Quote
Old   March 16, 2008, 08:34
Default hi all, i posted this message
  #12
robert maduta
hi all, i posted this message under the installation topics and now also here so that maybe you have an idea.
i did everything the way how michael described it in the tutorial he wrote. the problem is that when i try to compile everything i got the following error message:
robert@robert-laptop:~/OpenFOAM/OpenFOAM-1.4.1/applications/solvers/incompressible/simpleFoam$ wmake
g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/robert/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/robert/OpenFOAM/OpenFOAM-1.4.1/src/turbulenceModels -I/home/robert/OpenFOAM/OpenFOAM-1.4.1/src/transportModels -IlnInclude -I. -I/home/robert/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread Make/linuxGccDPOpt/simpleFoam.o -L/home/robert/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt \
-lincompressibleTurbulenceModels -lincompressibleTransportModels -lfiniteVolume -lmeshTools -lOpenFOAM -ldl penFOAM/linux/gcc-4.2.1/lib/libiberty.a -o /home/robert/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam
g++: penFOAM/linux/gcc-4.2.1/lib/libiberty.a: No such file or directory
make: *** [/home/robert/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam] Error 1
do i have to install any extra package to get rid of the problem? i already installed the binutils-dev package some time ago. i hope someone canhelp me
Old   March 16, 2008, 10:32
Default hi, there should be a page
  #13
Stephan Gerber
hi,
there should be a page called "how to compile openfoam". on this page you will find answers about the missing libiberty - i guess a partial reinstall of the binutils is what you need.
regards
stephan
Old   March 16, 2008, 15:56
Default Robert, Try to go to /home/ro
  #14
David Palko
dpalko is on a distinguished road
Robert,
Try to go to /home/robert/OpenFOAM/linux/gcc-4.2.1/lib and check if you have the file libiberty.a there. If not, try to download gcc-4.2.1 from OpenFoam webpage once more and unpack it. Maybe it helps.
David
dpalko is offline   Reply With Quote
Old   March 17, 2008, 03:06
Default jep, i already have the file.
  #15
robert maduta
jep, i already have the file. well i installed on another machine now suse and there after downloading the packages compiling works.
with adding a source term which has the exact value of my pressure gradient and setting pressure and everything as cyclic i dont get the suspected results. i took 700 cells in channel height direction and 2 to 4 in channel lenght direction. the solution always gives cyclic positive velocities at channel inlet and outlet and in the channel half negative velocities. should i change the number of cells in channel length direction to 1?
Old   March 17, 2008, 06:32
Default just to give an update. i thin
  #16
robert maduta
just to give an update. i think adding only a source term to the equation and choosing cyclic boundary conditions is not possible. i think the mass conservation is not necessarily fulfilled. i am trying to do my channel flow simulation now with boundaryFoam since i heard it works already with correctors for the mass conservation. the problem is that i dont see the boundaryFoam application in my FoamX-GUI. anyone knows what to do?
Old   April 14, 2008, 04:35
Default hi, i am trying to add a conc
  #17
davey david
suredross is on a distinguished road
hi,
i am trying to add a concentration equation to the icofoam solver to cater for different liquids of different concentrations.how do i go about it?should i follow the same procedure as how to add temperature?
thanks
davey
suredross is offline   Reply With Quote
Old   April 14, 2008, 09:25
Default hi Mike J, i was trying to fo
  #18
davey david
hi Mike J,
i was trying to follow your tutorial to add an equation(for concentration) to the icofoam solver but it seems not to be working for me.could you explain,please,how you got this eqn:
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(DT, T)
TEqn.solve?
i am new to Openfoam and cfd and cant seem to get around this obstacle.
thanks
davey
Old   March 19, 2009, 02:47
Default inquiry
  #19
andrianomena
sambatra is on a distinguished road
Hi there,
I'm kinda new to openfoam, and now I'm trying to learn more about it, it's very interesting but little hard. I got a question.
Can anybody comment a bit on this piece of code (it is in turbfoam code):
volScalarField rUA = 1.0/UEqn.A();
U = rUA*UEqn.H();
U-=rUA*fvc::grad(p);
what I dont get is the 'UEqn.A()' (access function?) and the "U-=rUA*fvc::grad(p)"
last one, what does "fvc::interpolate(U) & mesh.Sf()"
I know the syntax interpolate but my trouble is the meaning of "& mesh.Sf()"
sambatra is offline   Reply With Quote
Old   March 19, 2009, 02:54
Question inquiry
  #20
andrianomena
Hi there,
U = rUA*UEqn.H();
openfoam_aero likes this.
Adding Source term of a new field at the inlet vatant OpenFOAM Running, Solving & CFD 0 October 14, 2006 15:42
Adding Source term of a new field at the inlet vatant OpenFOAM Running, Solving & CFD 0 October 14, 2006 15:39
Adding a momentum source term segersson OpenFOAM Running, Solving & CFD 5 March 2, 2006 23:06
Adding a source term to continuity eqn(UDF) Sebeci FLUENT 0 April 20, 2003 03:12
adding source term confusion tedmcc CFX 4 September 27, 2001 05:05
