Home > Forums > OpenFOAM Running, Solving & CFD
MRFZonesC questions what is the mesh_V and why only Coriolis force no centrifugal force
Old   April 3, 2008, 04:00
Default http://www.cfd-online.com/Open
  #21
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
waynezw0618 is offline   Reply With Quote
Old   April 3, 2008, 04:01
Default b absolute velocity (at the sa
  #22
wayne.zhang
b absolute velocity (at the same conditon) calculated by CFX
Old   April 3, 2008, 04:03
  #23
wayne.zhang
Old   April 3, 2008, 04:06
Default Hi i am sorry.too too much t
  #24
wayne.zhang
Hi
i am sorry.too too much try maybe.and also there is no velocity(U=0)in hub and shroud boundays in my result.but i think there should be angular velocity like mixvessl2d'rotor.
i do not know why,can you help me ?
Old   April 3, 2008, 04:11
Default I agree something is strange i
  #25
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
I agree something is strange in picture a and b. It looks like you are rotating the impeller in opposite direction to the one presented from cfx. However, what you show in a and b cannot be relative velocities since they are not along the blades (as seen in the first picture from cfx).
Dragos
dmoroian is offline   Reply With Quote
Old   April 3, 2008, 04:25
Default i agree with " they are not al
  #26
wayne.zhang
i agree with " they are not along the blades",and they do not normal to the blade too.
and also there is velocity in the hub and the shroud (which is up and down boundary of the impeller).
what is wrong with it?
wayne
Old   April 3, 2008, 04:27
Default and also there is velocity in
  #27
wayne.zhang
and also there is no velocity in the hub and the shroud (which is up and down boundary of the impeller)
sorry.
Old   April 3, 2008, 05:27
Default and look at next two picture (
  #28
wayne.zhang
and look at next two picture (1 is foam ,2 is CFX)
1
2
you can find in foam calculation before the flow goes in to the blade it does not rotate,which is quiet differet from CFX result.
it also happened in the inlet boundary
so i guess it may be because of the faceSet or boundary condition,i am not quiet sure.
what is your idea?
wayne
Old   April 3, 2008, 05:30
Default foam http://www.cfd-online.co
  #29
wayne.zhang
foam
Old   April 3, 2008, 05:32
Default cfx http://www.cfd-online.com
  #30
wayne.zhang
cfx
Old   April 3, 2008, 05:57
Default I still think the impeller in
  #31
dmoroian's Avatar
Dragos
I still think the impeller in foam computation spins in opposite direction to the one in cfx.
foam: +0z
cfx: -0z
Most likely this is due to the fact that you did not impose rotation on the hub.
Dragos
Old   April 3, 2008, 10:32
Default Hi I still think the impelle
  #32
wayne.zhang
Hi
foam: +0z
cfx: -0z
i have checked that,the direction of rotation is the same in foam and cfx.or please look at the last two images,especially in cfx,the velocity vectors around axis (central of the blue circle in the underside of the cfx image,where the inlet pipe is nearby)are anticlockwise,if i impose a opposite direction,there would be an clockwise rotation for it near the inlet pipe,the roatation dirction of fluid in the inlet pipe and nearby will not intensively affect by the downstream.
so any other reasons?
_________________________________________________
Q2: how to impose the rotation on the hub? for the hub is wall,and MRFZones has boundary correction function which has impose the rotation to the boundary,and what will i do ? faceset(add hub and shroud to faceset or not delelet the boundary as what in the mixvessl2D?
Old   April 3, 2008, 10:41
Default by last, i mean in cfx result,
  #33
wayne.zhang
by last, i mean in cfx result, there is a rotation around the axia in evidence,the rotation direction is the same as i have imposed,but there is no rotation in Foam result.
i think it will a rotation of opposite diretion if i have spined a oppsite one
wayne
Old   April 3, 2008, 10:42
Default Can you display the MRFZones d
  #34
dmoroian's Avatar
Dragos
Can you display the MRFZones dictionary here?
Old   April 3, 2008, 13:31
Default Hi i am not working with my c
  #35
wayne.zhang
Hi
i am not working with my computer now.and i remember the omega is defined as [0 0 -1] 75.88
(impeller`s rotation speed is 725rpm, direction in -z).you could look at the "cfx" image carefully.at the right corner,z is to the inner,and the vector arround the inlet is clockwise.and angular velocity is in the -z.
wayne
Old   April 4, 2008, 07:15
Default This is why I want to see your
  #36
dmoroian's Avatar
Dragos
This is why I want to see your dictionary, because my impression is that you have a rotation axis defined as
axis axis [0 0 0 0 0 0 0] (0 0 1);
in foam. So please post it when you will be able to.
Old   April 6, 2008, 22:26
Default Hi i am sorry for i am aw
  #37
wayne.zhang
Hi
i am sorry for i am away for the passed few days. and now i am back to my office.
i have check for that right now,and you are right, i gave a wrong rotation axis dirction.i will modified it.
by how to impose the rotation to the boundary? do i need a faceSet?or others?
Old   April 7, 2008, 01:47
Default No you don't have to impose th
  #38
dmoroian's Avatar
Dragos
No you don't have to impose the velocity on the rotating wall. You just specify a normal wall "fixedValue" condition. If it is inside the rotating zone, then it will now how to impose the velocity correctly.
I'm glad you found the error,
Dragos
Old   April 7, 2008, 03:06
Default Hi how to impose? i try to m
  #39
wayne.zhang
Hi
how to impose?
i try to make a faceset like:
name IMPELLLER;//name of the cellzone
action new;
topoSetSources
boundaryToFace
and then modify the MRFZones Dictionary as:
5 //number of my rotating boundary..
IMPELLER //my cellZone
patches (HUB);//HUB is one of the rotating zone
origin origin [0 1 0 0 0 0 0] (0 0 0);
axis axis [0 0 0 0 0 0 0] (0 0 -1);
omega omega [0 0 -1 0 0 0 0] 75.92;
....//other rotating boundary such as shroud blade and so on
and specify all normal wall "fixedValue"
is that right?
wayne
Old   April 7, 2008, 03:21
Default and here is the vector of U on
  #40
wayne.zhang
and here is the vector of U on "HUB" whichi is rotating
Thread Tools
Trackbacks are On
Centrifugal force/ Rotating Wall david FLUENT 4 January 2, 2014 07:30
centrifugal force sue FLUENT 0 November 25, 2008 04:01
cyclone separator- centrifugal force kumar FLUENT 2 May 29, 2008 03:33
Cyclone separator-centrifugal force aPpA FLUENT 0 July 6, 2005 14:22
Coriolis force Saturn FLUENT 5 September 30, 2004 15:56
