Passing calculated values in parallel run
Old   April 1, 2008, 09:41
Default Hi, I have a problem with the
Christian Wesemeyer
wese is on a distinguished road
I have a problem with the parallel execution of OpenFOAM.
I've written a new boundary condition with calculated the input velocity profile of a square duct.
If I run my case on one processor I just have to calculate the values a single time when starting my calculation ( if(ldb.timeIndex() < 1)... ).
If I want to run my calculation in parallel mode I need to perform the calculation every time the program accesses the boundary condition (with is very often) and so I "waste" a lot of calculation time with a problem that doesn't change over time.
If I don't do so the velocity at my patch is set to some time varying value, from with I guess that it's calculated during execution.
How can I fix this problem?
I've already consulted the forum and the wiki (I've started with the parabolicinletVelocityprofile fot writing my BC) but was unable to find an appropriate hint how to do this.
Am I right, if I guess, that the problem is connected with the exchange of informations beween the processors?
Thanks in advance
Christian
wese is offline   Reply With Quote
Old   April 2, 2008, 02:13
Default Hi Christian, why do you need
Francesco Del Citto
fra76 is on a distinguished road
Hi Christian,
why do you need to calculate your BC only once in serial and many times in parallel? It sounds strange to me...
However, you can let all your processes to calculate your BC when needed. I mean, do your computation on each processor at the same time, instead of doing it on the master node and send the result to the other processes...
I hope this can help
Francesco
fra76 is offline   Reply With Quote
Old   April 2, 2008, 09:19
Default Hello Francesco, thanks for y
Christian Wesemeyer
Hello Francesco,
thanks for you reply.
Could you give me a hint how I do so, because I'm neither that much familiar with OpenFOAM nor with C++.
I guess a good idea would be, that the program check whether a file with the calculated values exists and if so reads it as input.
Otherwise the program should perform the calculation and write the output to the specific file.
Thanks in advance
Christian
Old   April 3, 2008, 05:43
Default Hello christian. It's not eas
Francesco Del Citto
Hello christian.
It's not easy to give you some hint, because I don't know exactly which is your problem...
If you can calculate the values you need, I guess you can avoid writing them to a file.
If your serial version works as you expect, simply let all the processors of a parallel run to do the same thing. If you rely on a file, you have to be sure that it exists at the beginning of the simulation, if you want to keep thing simple. Otherwise, if the file doesn't exist, simply calculate the values and store them in the BC data structure, without writing them to a file and read them back again.
If you want to store those values for any reason, you can let only the master process to write it:
if (Pstream::master())
[put your code here]
If you want to make the master to write the file and the rest to wait for it to finish, is a bit more complicated...
I hope this can help,
Francesco
Old   April 3, 2008, 07:45
Default Hi Francesco, thanks a lot fo
Christian Wesemeyer
Hi Francesco,
thanks a lot for your help.
I finally managed the problem with the parallel run by creating and writing a variable after the first calculation.
So every processor can perfom the calculation if needed.
Otherwise the data is just read out of the value variable.
For a total beginner in C++ the openFOAM code is really difficult, because everything is coded so efficently.
If you have any interest I can post my new boundary condition for the velocity profile of a square duct.
Greetings
Christian
Old   April 3, 2008, 08:47
Default Hi Christian, I started C++ m
Francesco Del Citto
Hi Christian,
I started C++ mainly for OpenFOAM, and from my point of view it is not so difficult, because everything is coded so efficiently and in an elegant way!
Try to put your hands in a badly written parallel code. It can be a nightmare, believe me...
It would be nice to have a look to the BC, if you can post it, thanks.
Francesco
Old   April 3, 2008, 10:04
Default Hi Francesco, maybe you're ri
Christian Wesemeyer
Hi Francesco,
maybe you're right.
At the moment I'm updating the document management system of our institute, which is written in PHP.
The scripts were created quick and dirty by someone several years ago.
Even if PHP is very simple to understand, all the encoded layout options really got me rid.
Compared to that openFOAM code is more than gold .
Attached you can find my new boundary condition which is an adaption of the parabolicVelocityProfile BC.
If you find any mayor mistakes or so please report.
squareVelocityProfile.tar.gz
Greetings
Christian
Writting own files calculated value during the run in Parallel anne OpenFOAM Running, Solving & CFD 12 May 27, 2008 15:53
Calculated Values in scalar field arkangel OpenFOAM Running, Solving & CFD 0 June 28, 2007 07:53
how to export calculated values to a file colin Fidelity CFD 1 June 5, 2007 04:14
How have boundary values set for calculated variables olwi OpenFOAM Running, Solving & CFD 5 August 25, 2006 11:56
Parallel UDF data passing causes Fluent to hang Tom FLUENT 2 June 9, 2006 13:17
