Governing equation for simpleFoam
Like Tree3Likes
  • 2 Post By newbee
  • 1 Post By grtabor
Old   April 24, 2006, 04:40
Default Hi, Im doing my thesis work an
newbee
Hi, Im doing my thesis work and need to know which the governing equations are for the simpleFoam application.
If I understand the code correctly it should be:
div(phi, U) + turbulence->divR(U)= -grad(p));
where:
-phi is the potential of U (but it has the dimension m³/s?)
what does turbulence->divR(U) represent?
what does the following lines do?
volScalarField AU = UEqn().A();
U = UEqn().H()/AU;
fumiya and 6863523 like this.
Old   April 24, 2006, 04:50
Default Hi! For the first part of y
Andreas Hauffe
andimb is on a distinguished road
Hi!
For the first part of your question I can help you. In the Programmer's Guide on page 54 you can see this equation. R is just nueff*grad(U) and nueff is nu+nut and is calculated by the turbulence model. Phi should be U in this case. And the p is pressure/density.
Andreas
andimb is offline   Reply With Quote
Old   April 24, 2006, 05:06
Default Hi! Ups, I think your right
Andreas Hauffe
Hi!
Ups, I think your right with phi. It is the potential of U. But part of the discretised form is multiplyed with a surface value because of the surface integrals, right?
Andreas
Old   April 24, 2006, 05:11
Default phi is in general the flux (rh
stefan
stefanke is on a distinguished road
phi is in general the flux (rho*u)
>U = UEqn().H()/AU;
This lines are need to precondition (jacobian) the U matrix.
hth
stefanke is offline   Reply With Quote
Old   April 24, 2006, 05:22
Default > what does turbulence->divR(U
Gavin Tabor
grtabor is on a distinguished road
This is the turbulence modelling. When you average the NSE you get back a very similar set of equations - the Reynolds Averaged Navier-Stokes equations - which have one additional term, which represents the effect of the fluctuations around the average (the turbulence) on the mean flow. We usually write this as div(R) where R is a 2nd rank tensor (the Reynolds Stress). Since we don't know this term (the closure problem) we need to model this; which is usually done by assuming that the turbulence has a dissipative effect and creating a 'turbulent viscosity' (which is usually so large it swamps the physical viscosity) and write R=-nu grad(u).
In FOAM this all gets swallowed into the turbulence model; turbulence->divR is getting this out of the model in a convenient (and mathematically stylish) way.
Gavin
Mehrez likes this.
grtabor is offline   Reply With Quote
Old   April 24, 2006, 05:42
Default Hi! As far as I understood
Andreas Hauffe
Hi!
As far as I understood these things in this case div(R) is not only the Reynolds stress tensor of the RANS equations. But it is only a question of definition I think.
div(R) = laplacian(nu,U) + Reynolds stress tensor
Andreas
Old   April 24, 2006, 05:52
Default Hi! Next mistake. It should
Andreas Hauffe
Hi!
Next mistake. It should be
div(R) = laplacian(nu,U) + div(Reynolds stress tensor)
There is a mistake in Hrv's PhD. Thesis on page 71.
Andreas
Old   April 24, 2006, 05:58
Default Thanks a lot! This was big
newbee
Thanks a lot!
This was big help. I will follow my papers on Reynolds equation on average flow values.
-a thought-
isnt div(UU)=2U*div(U)
which would give
1/2*div(phi, U) + turbulence->divR(U)= -grad(p));
Old   April 24, 2006, 06:12
Default No, there is no mistake in Hrv
Hrvoje Jasak
No, there is no mistake in Hrv's Thesis on page 71.
Hrv
Hrvoje Jasak
Old   April 24, 2006, 06:25
Default Hi! In this case I want to
Andreas Hauffe
Hi!
In this case I want to apologise to you for my mistake. But for my understanding I have to ask why in equation (2.30) the Reynold stress tensor is just added? So this equation consits of 5 vectors and a tensor.
Where is my mistake?
Andreas
Old   April 24, 2006, 06:32
Default Hmm, my mistake in fact: it sh
  #11
Hrvoje Jasak
Hmm, my mistake in fact: it should say div{(overline{Uprime Uprime})} right? and I am missing the div.
Will fix it asap.
Hrv
Hrvoje Jasak
Old   April 24, 2006, 06:40
Default Hi! I think div{(overline{U
  #12
Andreas Hauffe
Hi!
I think div{(overline{Uprime Uprime})} is right.
But your PhD thesis is just a great work to understand what OpenFOAM does. And in comparison to stupid things I'm telling sometimes it is without mistakes!
Andreas
Old   April 24, 2006, 07:02
Default where can I find this PhD thes
  #13
newbee
where can I find this PhD thesisk. It sounds like Ive could use a thing or two from it?
Old   April 24, 2006, 07:30
Default You can try the FOAM CFD resou
  #14
Hrvoje Jasak
You can try the FOAM CFD resource site http://www.foamcfd.org - there's quite a lot of stuff there including a bunch of PhD Theses done with OpenFOAM I managed to get in electronic form. Alternatively, you can try my personal web pages on http://www.h.jasak.dial.pipex.com.
Enjoy,
Hrv
Hrvoje Jasak
Old   April 2, 2008, 08:59
Default hi to all, I m a beginner i
  #15
kanarya
hi to all,
I m a beginner in OpenFoam and I want to program fluctuations with
tensor...
for example I want the following program to do with fluctuations.
magSqr(fvc::grad(U))+ sqr(gradU.component(tensor::YX) +
gradU.component(tensor::XY))
does someone can help me?
best regards
Old   April 2, 2008, 09:01
  #16
kanarya
hi to all,
tensor...
can someone help me?
best regards
governing equation of sliding mesh torn FLUENT 1 August 10, 2006 03:34
UDF to add two governing equation?? *NM* T.K. Yang FLUENT 0 May 9, 2006 03:03
UDF to add two governing equation?? T.K. Yang FLUENT 0 May 9, 2006 02:54
Linearisation of governing equations Märta-Karin Brandt CFX 3 November 14, 2003 09:33
1D governing equations Andrei Chernousov Main CFD Forum 5 July 13, 1999 15:06
