Buoyancydriven cavity flow
Old   March 12, 2008, 10:40
Default Hi, I try to simulate a buo
Anita K.
anita is on a distinguished road
I try to simulate a buoyancy-driven cavity flow like the example in "Computational Methods for Fluid Dynamics".
It is a square with adiabatic walls on the upper and lower side, a hot wall on the right side and a cold wall on left side. I define the temperature hot = 293 K, cold = 253 K and default 273 K.
The problem is that after starting the buoyantSimpleFoam solver there is an error.
Does somebody has a suggestion where the problem could be? I used the hotRoom-tutorial as basis.
I only changed turbulence model to laminar. Also with the k-epsilon modell there is the same problem.
Anita
Here is the log:
Exec : buoyantSimpleFoam . buoyancydriven32
Date : Mar 12 2008
Time : 16:26:08
Host : st31
PID : 25414
Root : /home/kienzani/OpenFOAM/kienzani-1.4.1/run/ownTests/ExamplesBook
Case : buoyancydriven32
Nprocs : 1
Create time
Create mesh for time = 0
Reading environmentalProperties
Reading thermophysical properties
Selecting thermodynamics package hThermo<puremixture<consttransport<speciethermo<hc onstthermo<perfectgas>>>>>
Reading field U
Creating turbulence model
Selecting turbulence model laminar
Calculating field g.h
Creating field pd
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 9.69948e-07, No Iterations 5
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.36774e-06, No Iterations 5
#0 Foam::error::printStack(Foam:stream&) in "/home/kienzani/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/kienzani/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xffffe420]
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/kienzani/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::tmp<foam::geometricfield<double,> > Foam::operator/<foam::fvspatchfield,>(Foam::GeometricField<double ,> const&, Foam::tmp<foam::geometricfield<double,> > const&) in "/home/kienzani/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/buoyantSi mpleFoam"
#5 main in "/home/kienzani/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/buoyantSi mpleFoam"
#6 __libc_start_main in "/lib/libc.so.6"
#7 Foam::regIOobject::readIfModified() in "/home/kienzani/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/buoyantSi mpleFoam"
anita is offline   Reply With Quote
Old   March 16, 2008, 08:54
Default Hi Anita, I have the same pro
aksouh mohamed
aksouh_med is on a distinguished road
Hi Anita,
I have the same problem, but for my problem is just 3d, and I have some results but I think that it didn't converge...so I had the errors message like :
Time = 139
Lookup gradScheme for grad(U)
Lookup divScheme for div((muEff*dev2(grad(U).T())))
Lookup laplacianScheme for laplacian(muEff,U)
Lookup divScheme for div(phi,U)
Lookup gradScheme for grad(rho)
Lookup gradScheme for grad(pd)
DILUPBiCG: Solving for Ux, Initial residual = 0.249057, Final residual = 1.70173e-06, No Iterations 5
DILUPBiCG: Solving for Uy, Initial residual = 0.0185925, Final residual = 4.28971e-06, No Iterations 4
DILUPBiCG: Solving for Uz, Initial residual = 0.104714, Final residual = 1.6076e-06, No Iterations 5
Lookup interpolationScheme for interpolate(rho)
Lookup interpolationScheme for interpolate(p)
Lookup laplacianScheme for laplacian(alphaEff,h)
Lookup divScheme for div(phi,h)
DILUPBiCG: Solving for h, Initial residual = 0.00378344, Final residual = 2.23355e-06, No Iterations 3
Lookup interpolationScheme for interpolate((rho*U))
Lookup snGradScheme for snGrad(rho)
Lookup interpolationScheme for interpolate(((rho*gh)*(1|A(U))))
Lookup laplacianScheme for laplacian((rho*(1|A(U))),pd)
DICPCG: Solving for pd, Initial residual = 0.332361, Final residual = 9.81432e-09, No Iterations 429
Lookup fluxRequired for pd
time step continuity errors : sum local = 8.58238e-08, global = -1.04862e-18, cumulative = 3.09173e-18
rho max/min : 1.20886 1.20063
ExecutionTime = 11054.2 s ClockTime = 11061 s
Anita try to change yr laminar model to turbulence model, but for low Reynolds number, like "LaunderSharmaKE'
so for me my questions are :
1- I don't know if I should change the interpolation scheme, and if there is the case which the good scheme for my problem?
2- I know that my problem is the heat transfer, so for the density, I have the boussinesq density in order to create flow between the cold and hot wall, but I dont know where can I find the boussinesq equation fo density.
thank you very much for your help.
aksouh_med is offline   Reply With Quote
Old   March 16, 2008, 09:14
Default Sorry, but I forgot to sent y
aksouh mohamed
Sorry,
but I forgot to sent you my fvScheme file :
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,h) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div((muEff*dev2(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(muEff,U) Gauss linear corrected;
laplacian((rho*(1|A(U))),pd) Gauss linear corrected;
laplacian(alphaEff,h) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
pd;
Thanks for all
Best regards
Old   March 26, 2008, 10:24
Default Hi, now the solver is worki
Anita K.
now the solver is working correct. I had initialized pressure with zero. After changing to 10000 calculation worked fine.
The new problem is that residual of U is falling the first 2500 slowly until below 0.001. Than it rises until 0.1. Afterwards it is nearly constant. Pressure residual does not even fall below 0.01.
Buoyancydriven cavity results for comparision kar OpenFOAM 0 April 14, 2008 09:04
2D Cavity Flow ALI RAJABPOUR Main CFD Forum 0 July 27, 2005 01:55
Flow in a cavity Herry CFX 1 April 27, 2003 18:30
Cavity flow Shannag Main CFD Forum 5 September 7, 2001 14:03
Cavity flow Sergey Smirnov Main CFD Forum 8 October 26, 2000 11:50
