Effects of turbulence on freesurface
Old   November 21, 2006, 11:21
Default I'm running rasInterFoam on a
sek
Sung-Eun Kim
sek is on a distinguished road
I'm running rasInterFoam on a free-surface problem. The tutorial says "the free-surface treatment in OpenFOAM does not account for the effects of turbulence...". Can someone who's familiar with the innerworking of FOAM please explain what this means?
sek is offline   Reply With Quote
Old   November 21, 2006, 11:25
Default It means it is using a single-
Hrvoje Jasak
It means it is using a single-phase turbulence model with no corrections for the density ratio or presence of free surface.
Hrv
Hrvoje Jasak
Old   November 21, 2006, 12:55
Default I see. Thanks, Hrv. Yet, the s
sek
Sung-Eun Kim
I see. Thanks, Hrv. Yet, the same paragraph of the tutorial (U-61, Chapter 2.3) continues "... as a consequence, all free surface somulations can be viewed as a direct numerical simulation of fluid flow...". I surmise this is not true. Even with a single-phase turbulence model, turbulent viscosity near free-surface would be much larger than molecular viscosity. And it is not going to be anything close to DNS. I would just take he entire paragraph as trying to remind us of the inherent limitations of the simple mixture-based turbulence model - it won't be able to describe complex turbulence physics near free-surface.
Old   November 9, 2007, 13:46
Default Hi, I am searching for a wa
marks
msang is on a distinguished road
I am searching for a way (hopefully simple) to correct the k-epsilon turbulence model in rasInterFoam for the effects of density ratio and free surface. I am mostly interested in the water phase, although this may not simplify the anything. Does anyone have suggestions for a reasonable staring point, references or a solver?
Thanks
Mark
msang is offline   Reply With Quote
Old   March 22, 2008, 21:48
Default Hi Mark I am interesting in
Onur Dundar
onurdundar is on a distinguished road
Hi Mark
I am interesting in the same concept. I found a paper has a simple approach to the solution of turbulence near the interface for k epsilon turbulence model.
onur
onurdundar is offline   Reply With Quote
Initializing freesurface in 3D geometry jaswi OpenFOAM Running, Solving & CFD 9 August 20, 2008 13:27
Need following paper about freesurface analysis Morteza Main CFD Forum 1 July 13, 2006 13:32
history effects of turbulence could u please.. bajjal Main CFD Forum 2 May 24, 2006 01:14
Difficult BCs about Freesurface Simulation by VOF Yongguang Cheng FLUENT 0 September 19, 2003 07:39
FreeSurface simulation Chengxuan Fu Siemens 0 January 27, 2001 06:08
