Dear OpenFoamers,
I have no
Dear OpenFoamers,
I have noticed some strange behavior of refineMesh utility. I have created an axisimetric 2D slice, using blockMesh, consisting of uniform hexahedra, here how it looks like: http://www.cfd-online.com/OpenFOAM_D...your_image.gif After applying refineMesh I obtained a refined mesh, but it seems a little strange near the axis of symmetry. The mesh seems to be not refined in a 2x2 manner through the middle of edges, as the refineMeshDict says. I tried various combinations of HexTopology and geometricCut entries, but I was never able to get a fine 2x2 refined mesh. My refined meshes looks like this: http://www.cfd-online.com/OpenFOAM_D...your_image.gif http://www.cfd-online.com/OpenFOAM_D...your_image.gif http://www.cfd-online.com/OpenFOAM_D...your_image.gif http://www.cfd-online.com/OpenFOAM_D...your_image.gif My blockMeshDict and refineMeshDict are: // blockMesh mesh description file /* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * */ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object blockMeshDict; } /* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * */ convertToMeters 0.001; vertices ( (0 0 0) (45 0 1.96474) (45 0 -1.96474) (0 45 0) (45 45 1.96474) (45 45 -1.96474) ); blocks ( hex (0 1 2 0 3 4 5 3) (45 1 45) simpleGrading (1 1 1) ); patches ( wedge wedgeFront ( (4 3 0 1) ) wedge wedgeBack ( (5 2 0 3) ) patch atmosphereTop ( (3 4 5 3) ) patch wallBottom ( (0 2 1 0) ) wall wallRightSide ( (5 4 1 2) ) empty centralAxis ( (0 0 3 3) ) ); mergePatchPairs ( ); /* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * */ // refineMesh description file FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object refineMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Cells to refine; name of cell set set c0; // Type of coordinate system: // - global : coordinate system same for every cell. Usually aligned with // x,y,z axis. Specify in globalCoeffs section below. // - patchLocal : coordinate system different for every cell. Specify in // patchLocalCoeffs section below. coordinateSystem global; //coordinateSystem patchLocal; // .. and its coefficients. x,y in this case. (normal direction is calculated // as tan1^tan2) globalCoeffs { tan1 (1 0 0); tan2 (0 1 0); } patchLocalCoeffs { patch outside; // Normal direction is facenormal of zero'th face of patch tan1 (1 0 0); } // List of directions to refine directions ( tan1 tan2 ); // Whether to use hex topology. This will // - if patchLocal: all cells on selected patch should be hex // - split all hexes in 2x2x2 through the middle of edges. useHexTopology no; // Cut purely geometric (will cut hexes through vertices) or take topology // into account. Incompatible with useHexTopology geometricCut no; // Write meshes from intermediate steps writeMesh yes; // ************************************************** *********************** // Does anyone knows what is wrong? Is this due to some internal control of OF, which does not allow 2x2 refinement of axisymetric meshes? Best Regards |
sorry, the images are here:
h
The cells at the wedge axis ar
The cells at the wedge axis are not hexes and that might give you problems. Either
- start off from all hexes, refine and only then make into wedge (wasn't there a makeAxialMesh on the Wiki?) or - try the geometricCut yes to not take into account any topology. Your mesh will have to be symmetric in the x-y plane. |
Thanks Mattijs!
I tried out
Thanks Mattijs!
I tried out the makeAxialMesh utility, it worked just fine |
