March 3, 2008, 16:48 |
I finally able to run my case
#21 |
Nishant
I finally able to run my case in parallel. There was some problem in the gcc installation. Now its working fine,.
Thank you .. Nishant
Thanks and regards, Nishant |
March 12, 2008, 10:17 |
I thought my parallel case is
#22 |
Nishant
I thought my parallel case is running, but actually it was not. However I can see the program running on queue. Error file is saying that..
ERROR: A daemon on node comp26 failed to start as expected. As i mentioned earlier my mpirun -hostfile machine <rooot> <case> -parallel command is running quite well on cluster directly. I mean to say that it's working fine if we run on master node (for us its kittyhawk.dcs.hull.ac.uk) but it fails on any other node ( like comp01/02/10/11 etc) I tried a hello mpi programm as well but that also failed to run using qsub and running quite well directly on master kittyhawk. my gcc compiler is unable to compile a program on any other node except master node kittyhawk. however they are using the right gcc (that is openfoam version of gcc) Again, I am using cluster's version of MPICH as PE. (#$ mpich -pe 4), which is installed at /usr/.....** The default PE environment here is >>score<< which we run using mpisub command. Do I need to use a local version of mpich in order to run in parallel using qsub? Or could it be possible to run openfoam program using score? can anybody suggst something? regards, Nishant
April 17, 2009, 11:21 |
Running OpenFOAM in parallel with SGE
#23 |
to run openFOAM in parallel with SGE, you need to make sure that the following requisites are satisfied: 1) use an openmpi version >= 1.2.0 The reason is that any version prior to that isn't working with SGE. 2) Make sure that you define a parallel environment, for instance "orte", with the following definition (that's here for 8 parallel slots = 8 cores in parallel): pe_name orte slots 8 user_lists NONE xuser_lists NONE start_proc_args /bin/true stop_proc_args /bin/true allocation_rule $round_robin control_slaves TRUE job_is_first_task FALSE urgency_slots min 3) Submit your job with (for example with a run on 8 cores): qsub RUN.sh where RUN.sh contains: #!/bin/sh #$ -V ### number of processors and parallel environment #$ -pe orte 8 ### Job name #$ -N "mypartest" ### Start from current working directory #$ -cwd ### Generate the hostfile HOSTFILE=system/hostfile awk '{print $1" cpu=1"}' ${PE_HOSTFILE} > ${PWD}/${HOSTFILE} ### Run application SOLVER=icoFoam ${MPI_ARCH_PATH}/bin/mpirun -np ${NSLOTS} --hostfile ${PWD}/${HOSTFILE} ${FOAM_APPBIN}/${SOLVER} -parallel exit $? You will also find further information at: http://www.open-mpi.org/faq/?categor...run-scheduling Alternatively, you can try to compile MPICH from source. I've been able to run v1.2.7p1 without any dramas. This is quite straightforward if you take a look at the Allwmake scripts in $WM_THIRD_PARTY. Hope this helps... |
January 18, 2010, 08:10 |
Problem with openFoam and SGE
#24 |
Cárdenas
Hello to all,
I'm trying to run openFoam on a SGE Sun Cluster. When running the job on parallel in a single node, everything works. But when trying to run the same job on different nodes, I get the following error message: epsilon2.o31752: PHP Code:
------------------------------------------------------------------------------ #!/bin/tcsh # This is a simple example of a SGE batch script #$-o /nfs/home/cardenas/Documents/OpenFOAM/Cases/Platte/Laenge120mm/Pulsierend/eps ilon2 -j y #$-N epsilon2 #$-pe batch_64_2 2 #$-S /bin/tcsh touch $HOME/.ssh/known_hosts cd /nfs/home/cardenas/Documents/OpenFOAM/Cases/Platte/Laenge120mm/Pulsierend/epsilon2 touch -a ./*.* touch -a ./system/* source /nfs/home/cardenas/OpenFOAM/OpenFOAM-1.6.x/etc/cshrc cat $PE_HOSTFILE |awk '{ print $1 " cpu=" $2}' > $HOME/mpi/machines.LINUX.$JOB_ID sleep 10; mpirun --hostfile $HOME/mpi/machines.LINUX.$JOB_ID -np 2 icoFoam -parallel >log ----------------------------------------------------------------------------------------------- It seems that something with the Host Keys is not working properly, but since I'm not expirienced in SGE, I would appreciete any suggestions and hints. Thank you very much Alejandro |
January 19, 2010, 03:10 |
#25 | ||
Mark Olesen
Rep Power: 40 |
The very first thing it to determine if GridEngine support has been compiled into your openmpi. Use the command "ompi_info" to list all the backends and grep for gridengine. If it's not there, you should recompile openmpi using the --with-sge configure option (see the third-party Allwmake). ^^^ what is this? Touching a file into existence doesn't make the hosts known! Quote:
If the final backend uses rsh, ssh, or the GridEngine builtin transport will depend on what you have configured as the 'rsh_command' and 'rsh_daemon' in GridEngine. BTW: your example is using cshell. Be certain that the queue is configured with the corresponding shell_start_mode. Be default this will be 'posix_compliant' (ie, use /bin/sh) and not 'unix_behavior' (ie, use #! to determine the shell/program). |
October 27, 2011, 10:03 |
Pending but not running
#26 |
I also tried to run OpenFoam in parallel with SGE. I use the following script to submit the job: Code:
#!/bin/csh #$ -V ###set queue #$ -q normal ### number of processors and parallel environment #$ -pe OpenFOAM 4 #$ -S /bin/csh ### Job name #$ -N "mypartest" ### Start from current working directory #$ -cwd source ./soft/OpenFOAM/OpenFOAM-2.0.0/etc/cshrc ### Run application mpirun -np ${NSLOTS} pisoFoam -parallel Code:
xhost: Command not found. : Command not found. : Command not found. : Command not found. : Command not found. /soft/OpenFOAM/OpenFOAM-2.0.0/etc/cshrc : No such file or directory. I don´t know why the grid engine can´t find the command. Does anybody have an idea why it doesn’t work? Or are there any settings I have to modify? I´m thankful for any help Stefan Last edited by schteff; November 21, 2011 at 04:26. |
May 4, 2012, 11:56 |
#27 | |
Ricardo Reis
HOSTFILE=system/hostfile awk '{print $1" cpu="$2}' ${PE_HOSTFILE} > ${PWD}/${HOSTFILE} |
May 4, 2012, 11:57 |
#28 | |
Ricardo Reis
/soft/OpenFOAM/OpenFOAM-2.0.0/etc/cshrc without the initial . ? |
August 22, 2012, 09:27 |
solution to "Host key verification failed"
#29 |
Timo Kulju
Hi!
If somebody is having problems with host-keys, adding a line Code:
StrictHostKeyChecking no Code:
/etc/ssh/ssh_config Code:
export OMPI_MCA_orte_rsh_agent=ssh |
CFX integration with Sun Grid Engine | mausmi | CFX | 2 | February 4, 2016 16:30 |
Grid Engine OpenFOAM15dev and OpenMPI124 | tian | OpenFOAM Installation | 11 | February 26, 2009 10:43 |
Running parallel job using qsub on sun grid engine | nishant_hull | OpenFOAM Running, Solving & CFD | 5 | February 7, 2008 14:52 |
IC engine | Araz Banaeizadeh | Main CFD Forum | 0 | June 28, 2006 22:56 |
CFX and Sun Grid Engine | David Hargreaves | CFX | 1 | August 25, 2005 23:50 |
