Nonuniform initial condition using cellSetDict |
August 24, 2008, 09:13 |
I'm trying to set diffe
Rina Oldek
Rep Power: 17 |
I'm trying to set different initial conditions for a set of cells. In the interFoam example, the boxToCell rule was used, hoewver, in my problem the boundary is not rectangular but rather circular. What are the exact command lines that I should write in the setCellDict? Should I specify each cell explicitly? Thanks, Rina |
October 22, 2008, 04:46 |
Hi Kathrin,
Thanks for your m
Rina Oldek
Rep Power: 17 |
Hi Kathrin,
Thanks for your mail. I have another question: if the blocks have a cyclic side, which command should I use? The code that you sent is for a sphere, which is not the case for me. The block has 3 straight lines and one is cyclic. How should I write the initial conditions? Thanks again, Rina |
June 22, 2009, 06:31 |
isabel
Rep Power: 16 |
I am changing the interFoam tutorial to define a sphere of ratio 1 as initial condition. Does anybody know the error in this setFieldsDict file?
FoamFile { version 2.0; format ascii; class dictionary; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue gamma 0 volVectorFieldValue U (0 0 0) ); regions ( sphereToCell { sphere (0 0 0) (0 0 1); fieldValues ( volScalarFieldValue gamma 1 ); } ); // ************************************************** *********************** // |
November 26, 2009, 08:03 |
Answer
Correct is that syntax:
sphereToCell { centre (0.02 0.135 0); radius 0.01; fieldValues ( volScalarFieldValue gamma 1 ); } |
November 9, 2011, 11:30 |
Concordia_CFD
Rep Power: 15 |
Hello all,
does sphereToCell work the same way in 2D axisymmetric cases? The thing is that i want to patch a droplet with this syntax in setFieldsDict, but I get a cylinder instead of a droplet!! I tried funky function and cellSetDict but I got the same cylinder. Any help is greatly appreciated, thank you. Marzbali |
January 8, 2013, 12:53 |
Hossein Yahyazadeh
Rep Power: 13 |
Hi every body,
could somebody help me to set an elliptic drop instead? thanx |
January 9, 2013, 00:42 |
Daniele Vicario
Rep Power: 17 |
I've never use it but funkySetFields should work.
See http://openfoamwiki.net/index.php/Co...funkySetFields example at point 5. In 3D you can use the ellipsoid equation http://en.wikipedia.org/wiki/Ellipsoid Regards,
Daniele Vicario blueCFD2.1 - Windows 7 |
Specifying nonuniform initial condition | msyaml | OpenFOAM Running, Solving & CFD | 65 | April 25, 2016 04:23 |
Specifying nonuniform boundary condition | maka | OpenFOAM Running, Solving & CFD | 59 | October 22, 2014 14:52 |
Initial Condition | Tang Kuei | FLUENT | 0 | May 17, 2006 19:54 |
Nonuniform gradient boundary condition | ankgupta8um | OpenFOAM Running, Solving & CFD | 1 | March 14, 2006 01:34 |
Nonuniform initial conditions | nico | OpenFOAM Pre-Processing | 2 | January 4, 2006 06:37 |
