Hooking new BC is not successful
Old   March 5, 2008, 08:29
Default Hello to FOAMing user, I am w
David Sponiar
sponiar is on a distinguished road
I am working very hard on to implement new BC. My situation is quite strange:
While I am compiling new BC I follow this 3 basic steps:
____________
• compile new BC, which create new library
• compile foamUser, which called new BC's library
• compile little bit modified simpleFoam, which called updated foamUser's library
____________
Every steps are finished successfuly, it means: new dynamic library are update and modified simpleFoam is compiled without any errors.
When I run application simpleFoam with case, where is new BC defined on outlet, FOAM FATAL ERROR says to me:
"Unknown patchField type modifiedOutlet for patch type patch"
The strange thing is to me, when I follow same compiling steps on another PC (notebook with OpenSuSE 10.3.) with same source codes, I can successfuly hook new BC.
I was looking for any mistake for two days. I did not find anything weird. So I packed whole OpenFOAM directory on notebook and copy and unpacked on worskation with SuSE Linux Enterprise Desktop 10.0.
foamInstalationTest is after that OK. Every is OK, but after 3 compiling steps, new BC is unknown.
Give me please any hint, where could be any mistake. Thans a lot.
David
I attach list of Make/files and Make/options from new BC, foamuser and modified simpleFoam:
__________________________
• new BC Make/files
modifiedOutlet.C
LIB = $(FOAM_LIBBIN)/libNewBC
• new BC Make/options
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude
LIB_LIBS = \
-lfiniteVolume
• foamUser Make/files
libfoamUser.C
LIB = $(FOAM_USER_LIBBIN)/libfoamUser
• foamUser Make/options
LIB_LIBS = \
-lNewBC
• simpleFaom Make/files
simpleFoamModified.C
EXE = $(FOAM_USER_APPBIN)/simpleFoamModified
• simpleFaom Make/options
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/turbulenceModels \
-I$(LIB_SRC)/transportModels \
-I$(FOAM_USER_LIBBIN)
EXE_LIBS = \
-lincompressibleTurbulenceModels \
-lincompressibleTransportModels \
-lfiniteVolume \
-lmeshTools
LIB_LIBS = \
-lfoamUser
sponiar is offline   Reply With Quote
Old   March 5, 2008, 13:55
Default David, to answer your quest
kar
Kārlis Repsons
kar is on a distinguished road
David,
to answer your question it is necessary that you post in relevant BCs in /0/{U,p,...} and beginning of BC class definition (if you didn't wrote it from scratch, that is - if you modified some OF's class)!
Kārlis
kar is offline   Reply With Quote
Old   March 6, 2008, 17:21
Default David, some ideas for you:
kar
Kārlis Repsons
David,
some ideas for you:
* what happens if you compile your BCs in solver? (I agree it's better to make a libraries, but maybe you can try that - just add *.C files to Make/files)
* be sure to access solver variables in a right way (take a look at buoyantFoam's BCs, parabolic U inlet etc)
* Its not likely to be the case for problem you stated, but it's not a very good idea to use in code things you don't know about.
Kārlis
Old   March 6, 2008, 19:00
Default Hello Kārlis, It's kind of y
David Sponiar
Hello Kārlis,
It's kind of you, that you are responding to my problem with implementing new BC. I'll promise to share my progres in "fighting with my implementation new BC and self-conquest".
When I compile modified simpleFoam with calling dynamic library (noticed above), every goes right way = compiling is successful and new application simpleFoamModified is created. But hookin new BC type in boundary file /0/q is not successful.
Actualy, I copy source code of totalPressure BC, just rename everything in code to modifiedOutletFvPatchScalarField and added new operator with evaluating mathematical operations with normal gradients. (Of course with regards to corect programing standard in C++ and OpenFOAM philosophy).
Strange thing is to me, that same code in same OpenFOAM, but on another PC was compilied and implemented succesfull.
I'll check my steps and share my more or less satisfactory progres.
David
Old   March 7, 2008, 06:31
Default The easiest way of exposing ex
Eugene de Villiers
eugene is on a distinguished road
The easiest way of exposing existing solvers and utilities to new boundary conditions is to add an entry like this to your controlDict:
libs ("<path>/<library>");
Much easier than recompiling and copying stuff around.
eugene is offline   Reply With Quote
Old   March 7, 2008, 08:05
Default Hello foaming users, I find t
David Sponiar
I find the right way: After lot of testing combination, I added this line:
libs ("libfinite.so");
to /system/controlDict and simpleFoam goes smoothly without any FOAM FATAL ERROR.
That's the way!
David
Successful Installation My report quartzian OpenFOAM Installation 2 April 30, 2009 03:59
Successful PhD grtabor OpenFOAM Running, Solving & CFD 2 February 24, 2009 04:08
Problem FoamXHostBrowser not found after successful compilation david_flo1 OpenFOAM 0 January 21, 2008 22:04
UDF Hooking Bhaskar Roy FLUENT 1 April 20, 2006 01:50
Hooking Problem bowling FLUENT 0 April 30, 2004 04:38
