Random field
Old   February 18, 2008, 11:03
Default Hi, I would like to create
John Deas
johndeas is on a distinguished road
I would like to create a random vector field with which I could play with my flow (adding it to velocity components as a white noise, or as a body force in the NS equation,...).
Since I still do not catch well how data is organised within OpenFOAM, could somebody help me ? I know the object for this field would be a volVectorField, but I do not get much...
I would like values to be independent for each positions and components, and spanning between 0 and 1.
Thanks,
JD
johndeas is offline   Reply With Quote
Old   February 18, 2008, 13:52
Default I tried to modify perturbU fro
John Deas
I tried to modify perturbU from De Villier :
#include "fvCFD.H"
#include "Random.H"
#include "wallDist.H"
#include "wallDistReflection.H"
#include "mathematicalConstants.H"
int main(int argc, char *argv[])
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
wallDist yw(mesh);
const scalar h = max(yw.internalField());
wallDistReflection reflexVec(mesh);
const volVectorField yDir = reflexVec.n();
IOobject Uheader
"U",
runTime.timeName(),
mesh,
IOobject::MUST_READ
Info << "Reading U" << endl;
volVectorField U(Uheader, mesh);
IOdictionary transportProperties
IOobject
"transportProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
dimensionedVector Ubar
transportProperties.lookup("Ubar")
vector xDir = Ubar.value()/mag(Ubar.value());
const vectorField& centres(mesh.C());
Random perturbation(1234567); // objet possède la méthode GaussNormal
forAll(centres, celli)
scalar devX=1.0 + 0.1*perturbation.GaussNormal();
scalar devY=1.0 + 0.1*perturbation.GaussNormal();
scalar devZ=1.0 + 0.1*perturbation.GaussNormal();
vector zDir = xDir^yDir[celli];
zDir /= mag(zDir);
U[celli] = 3.0*Ubar.value() * (yw[celli]/h - 0.5*sqr(yw[celli]/h));
U[celli] += xDir*devX+yDir*devY+zDir*devZ;
U.write();
Info<< endl;
return(0);
But this line
is a source of compilation error:
sandFoam.C:69: error: no match for 'operator+=' in 'U.Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh>::<anonymous>.Foam::DimensionedField <foam::vector<double>, Foam::volMesh>::<anonymous>.Foam::Field<foam::vect or<double> >::<anonymous>.Foam::List<foam::vector<double> >::<anonymous>.Foam::UList<t>::operator[] [with T = Foam::Vector<double>](celli) += Foam::operator+(const Foam::tmp<foam::geometricfield<type2,> >&, const Foam::VectorSpace<form,>&) [with Form = Foam::Vector<double>, Cmpt = double, int nCmpt = 3, Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::VectorSpace<foam::vector<double>, double, 3>&)((const Foam::VectorSpace<foam::vector<double>, double, 3>*)(& Foam::operator*(const Foam::VectorSpace<form,>&, Foam::scalar) [with Form = Foam::Vector<double>, Cmpt = double, int nCmpt = 3](devZ).Foam::Vector<double>::<anonymous>))))'
/home/vinz/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/VectorSpaceI.H:204: note: candidates are: void Foam::VectorSpace<form,>::operator+=(const Foam::VectorSpace<form,>&) [with Form = Foam::Vector<double>, Cmpt = double, int nCmpt = 3]
However I thought I provided my deviation as a three component vector, so I do not understand where the problem is.
Old   February 19, 2008, 03:08
Default Hi John, Maybe you can have
Cedric DUPRAT
cedric_duprat is on a distinguished road
Hi John,
Maybe you can have a look there : src/randomProcesses
there is a file noise and an other turbulence.
I think they could be interresting for you.
With perturbU, you can already add a noise near the wall (without adding the laminar velocity profile for U).
Can you precise what you want do to ?
Regards
Cedric
cedric_duprat is offline   Reply With Quote
Old   February 19, 2008, 04:17
Default I am trying to reproduce resul
John Deas
I am trying to reproduce results we get on another code (DNS), perturbing a Poiseuille profile with white noise at 1/10 the original local field value.
I noted perturbU and will give it a try later.
Since turbgen generates divergence free turbulent field, I may also try to surimpose one it produces with a Poiseuille profile.
Anyway if someone understands why U[celli] += xDir*devX+yDir*devY+zDir*devZ; throw me an error in the modification I did...
Old   February 25, 2008, 05:53
Default I corrected my error: yDir was
John Deas
I corrected my error: yDir was declared of type volVectorField, and, as such, the perturbation had to be written:
U[celli] += devX*xDir+devY*yDir[celli]+devZ*zDir;
instead of:
U[celli] += devX*xDir+devY*yDir+devZ*zDir;
How to get Pressure field from velocity field qunwuhe@hotmail.com Main CFD Forum 4 October 14, 2007 07:38
Putting submesh field values into field on parent mesh helmut OpenFOAM Running, Solving & CFD 2 June 20, 2006 07:31
UDF and random functions gino briganti FLUENT 2 June 28, 2005 04:55
random posrosity shekhar FLUENT 5 October 13, 2003 23:45
field by field decomposition vs. component-wise zhanglei Main CFD Forum 0 January 5, 2001 09:06
