May 16, 2006, 05:11 |
Ok,
I will run channelOoles
#21 |
anne dejoan
Rep Power: 17 |
Ok,
I will run channelOoles tutorial on my grid to test if I have the same error. Once I have the result I will let you know, Anne |
May 16, 2006, 06:39 |
I come back with mor
#22 |
Mélanie Piellard
Rep Power: 17 |
I come back with more info. I could not run on OF 1.3 because unfortunately I have problems downloading the files (this should be because of the firewall we have here...). Anyway, I ran the pitzDaily tutorial as Mattijs suggested, and after more than 4 hours, I did not notice a memory increase. This means for me that something is wrong with my settings and/or my mesh, as Anne suggested for her case. If you have a look at the thread "Memory leaks", you can see that I also posted my error there because Hrvoje had the same problem last year with interFoam, and it seems that it came from an assignement problem in a scheme. Melanie |
May 16, 2006, 06:42 |
... which was fixed in OF1.3 .
#23 |
Mattijs Janssens
Rep Power: 26 |
... which was fixed in OF1.3 ...
So when you get the chance to download 1.3 let me know if you can/cannot repeat your problem. |
May 16, 2006, 11:33 |
I run a oodles case on a mesh
#24 |
Xiaofeng Liu
Rep Power: 17 |
I run a oodles case on a mesh of about 1.4M cells. For about 4 steps, it run out of memory.
Then I trid valgrind. It even couldn't start. Here is the out put: $ valgrind --tool=memcheck oodles . pile ==16908== Memcheck, a memory error detector for x86-linux. ==16908== Copyright (C) 2002-2004, and GNU GPL'd, by Julian Seward et al. ==16908== Using valgrind-2.2.0, a program supervision framework for x86-linux. ==16908== Copyright (C) 2000-2004, and GNU GPL'd, by Julian Seward et al. ==16908== For more details, rerun with: -v ==16908== ==16908== warning: mmap failed on /home/liu19/research/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPDebug/libfiniteVolume. so ==16908== no symbols or debug info loaded /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : oodles . pile Date : May 15 2006 Time : 20:14:04 Root : /home/liu19/research/OpenFOAM/liu19-1.3/run/tutorials/oodles Case : pile Nprocs : 1 Create time Create mesh, no clear-out for time = 0 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi ==16908== Warning: set address range perms: large range 105426480, a 0, v 1 ==16908== Warning: set address range perms: large range 105426480, a 0, v 1 **16908** new/new[] failed and should throw an exception, but Valgrind cannot throw exceptions and so is aborting instead. Sorry. ==16908== at 0x1B90484E: VALGRIND_PRINTF_BACKTRACE (valgrind.h:229) ==16908== by 0x1B904D63: operator new[](unsigned) (vg_replace_malloc.c:139) ==16908== by 0x80948D4: Foam::List<foam::vector<double> >::List(int) (List.C:59) ==16908== by 0x809494B: Foam::Field<foam::vector<double> >::Field(int) (Field.C:54) ==16908== ==16908== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 46 from 2) ==16908== malloc/free: in use at exit: 554779838 bytes in 4398686 blocks. ==16908== malloc/free: 4438499 allocs, 39812 frees, 856829490 bytes allocated. ==16908== For a detailed leak analysis, rerun with: --leak-check=yes ==16908== For counts of detected errors, rerun with: -v
Xiaofeng Liu, Ph.D., P.E., Assistant Professor Department of Civil and Environmental Engineering Penn State University 223B Sackett Building University Park, PA 16802 Web: http://water.engr.psu.edu/liu/ |
May 16, 2006, 12:54 |
Hi Liu,
Do you have a small
#25 |
Mattijs Janssens
Rep Power: 26 |
Hi Liu,
Do you have a smaller case meshed using blockMesh which has the same problem? |
May 16, 2006, 13:32 |
Sorry, I don't.
I tried smal
#26 |
Xiaofeng Liu
Rep Power: 17 |
Sorry, I don't.
I tried smaller case whose mesh comes from Gambit. It didn't give problem at least in the 1000 or so time steps. The reason valgrind couldn't start up is maybe it needs more memory to record the behavior of the program. But it's so strange that without valgrid it quits after several steps. Mattijs: Can you send me an example 3D LES test case (other than the tutorial toy problem) that I can run on my computer? I have no idea how fine the grid should be. That's why I ended up with 1.4M cells for a simple flow-past-cylinder case. What I am trying to get is something like: http://www.iihr.uiowa.edu/people/res...imation1-4.htm
May 16, 2006, 13:52 |
You could be running just out
#27 |
Mattijs Janssens
Rep Power: 26 |
You could be running just out of virtual memory for another reason than OF memory leaking. As said on the tutorial case (which is the only one I have to answer your question) I see no leakage at all.
You can try taking over the settings from your big case (turb model, solver settings, bs's) onto that one and see if it behaves differently. |
May 16, 2006, 14:06 |
Ok. I turned off all other pro
#28 |
Xiaofeng Liu
Rep Power: 17 |
Ok. I turned off all other programs and let oodles run on this 1.4M mesh.
Here is the result at the sixth step: Time = 6e-05 Mean and max Courant Numbers = 0.000306349 0.016599 BICCG: Solving for k, Initial residual = 0.068446, Final residual = 6.60569e-09, No Iterations 1 new cannot satisfy memory request. This does not necessarily mean you have run out of virtual memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library Aborted If I am running out virtual memory, why is it at this step? I monitored the system and the unused memory is still plenty. I tried smaller case. No memory problem. But it didn't generate turbulence either.
May 22, 2006, 08:58 |
(I eventually manage
#29 |
Mélanie Piellard
Rep Power: 17 |
(I eventually managed to download and install OF 1.3...) Now I have run OF 1.3 on the same case as previously, and I still have an increase of the memory consumption during the run: after 3 hours, the memory increase is more than 200 Mb. The job is running on the same machine as before. Thanks for your help ! mélanie |
May 23, 2006, 04:28 |
Does your setup consist of:
#30 |
Mattijs Janssens
Rep Power: 26 |
- OpenFOAM 1.3 - an unmodified solver - a tutorial testcase or another case which uses blockMesh to generate the mesh. |
May 24, 2006, 04:08 |
My setup is the unmodified sol
#31 |
Mélanie Piellard
Rep Power: 17 |
My setup is the unmodified solver oodles of OF 1.3, but I have built the testcase by myself, using an imported mesh (from Fluent). It contains cyclic BC. I use a Crank-Nicholson time scheme, and the spatial schemes are Gauss linear or Gauss limited linear. If you need more details, please let me know.
Thanks ! |
May 25, 2006, 05:56 |
Can you set up a blockMeshable
#32 |
Mattijs Janssens
Rep Power: 26 |
Can you set up a blockMeshable case which has the same behaviour?
June 13, 2006, 10:22 |
I tried all my settings on the
#33 |
Mélanie Piellard
Rep Power: 17 |
I tried all my settings on the oodles tutorial, but I was not able to reproduce the error... and I don't have another blockMeshable case !
If you have one to submit, I will try. |
June 13, 2006, 12:37 |
- have you run checkMesh on yo
#34 |
Mattijs Janssens
Rep Power: 26 |
- have you run checkMesh on your case
- did you try the crank-nicholson scheme on the tutorial case - can I download your case or can you send it to me? |
June 14, 2006, 03:32 |
- of course I ran checkMesh wh
#35 |
Mélanie Piellard
Rep Power: 17 |
- of course I ran checkMesh when I set up the case, everything OK (I just re-ran it to be sure).
- I had exactly the same settings on the tutorial case as on my case, actually I made a copy of controlDict, turbulenceProperties, transportProperties, fvSolution and fvSchemes and it ran as is - I can send you my case if you leave me your adress or write me at melanie_piellard@yahoo.fr ... although it is quite big: ~200 Mo for the definition and one time step. |
June 15, 2006, 02:48 |
Hi Melanie,
Unfortunately,
#36 |
Hrvoje Jasak
Rep Power: 33 |
Hi Melanie,
Unfortunately, my machine is not big enough to run your case under valgrind but I tried two other things. I have run oodles on a smaller mesh with memory checking switched on and there are no problems to report, I have left your case running over night on the machine and it runs without obvious problems. The memory jumped form 1.2 to 1.4 GB quite early in the simulation but after that remained stable for a number of hours. In short, I cannot see any problems with the code. This leaves 2 possibilities: - there may be a problem with your operating system (I have had quite a lot of trouble with Suse-9.1 a while back) - there may be a slight inconsistency between the compiled version of OpenFOAM and your operating system setup. I would therefore recommend you try to patch up the operating system to the latest level of patches and completely recompile OpenFOAM. Please keep me posted, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
June 15, 2006, 03:37 |
Hrvoje,
I am surprised that
#37 |
Mélanie Piellard
Rep Power: 17 |
Hrvoje,
I am surprised that on your machine, the memory only jumps to 1.4 Gb and remains stable... 1.2 Gb is the "normal" consumption for this case, and the resident memory keeps around this value. This is the virtual memory that (should) increase a lot. I will check my OS, but what is strange is that I already ran oodles on other cases (mainly 2D smaller cases), and I did not have this problem, nor with other solvers (lesInterFoam, coodles, simpleFoam) melanie |
June 15, 2006, 03:45 |
The OS is SuSE Linux 9.3 Profe
#38 |
Mélanie Piellard
Rep Power: 17 |
The OS is SuSE Linux 9.3 Professional; are you aware of certain versions/patches that could impact the performance of OF ?
June 19, 2006, 02:32 |
Hi Mattijs,
were you able to
#39 |
Mélanie Piellard
Rep Power: 17 |
Hi Mattijs,
were you able to reproduce the error ? melanie |
June 19, 2006, 02:45 |
Not sure. Started at 1.2-1.4 a
#40 |
Mattijs Janssens
Rep Power: 26 |
Not sure. Started at 1.2-1.4 and then went up to 1.5 after a few hours. Hard to tell though since memory consumption (mainly in the AMG solver) varies a lot.
This was on Suse10.1 machine. Also Hrvoje doesn't see this problem on small case. Does backward differencing instead of Crank Nicholson have the same problem? |
A question on DES oodles | ivan_cozza | OpenFOAM Running, Solving & CFD | 2 | November 17, 2008 09:33 |
electric resistance energy consumption | nilay | FLUENT | 0 | October 10, 2008 10:46 |
Oodles and more | r2d2 | OpenFOAM Running, Solving & CFD | 10 | September 23, 2007 01:54 |
Oodles vs turbFoam | rolando | OpenFOAM Running, Solving & CFD | 9 | June 4, 2007 05:42 |
transport-consumption problem | giskard | FLUENT | 0 | November 4, 2006 08:34 |
