Home > Forums > OpenFOAM Running, Solving & CFD
Convectiondominated schemes
Old   February 10, 2008, 13:09
Default Hi, All! Please, answer my
Dmitry Kovtunov
dak81 is on a distinguished road
Hi, All!
Please, answer my question. Is it possible to
solve the convection-diffusion equation with OpenFOAM when convection is dominated?
dak81 is offline   Reply With Quote
Old   February 10, 2008, 13:22
Default Yes - in fact, it is quite eas
Hrvoje Jasak
Yes - in fact, it is quite easy.
Hrvoje Jasak
Old   February 10, 2008, 13:58
Default Thanks for the answer. But cou
Dmitry Kovtunov
Thanks for the answer. But could you point to my mistake? I was doing so:
solve(- fvm::laplacian(T) + (u & fvc::grad(T)) == f);
where T - temperature
u - predefined analytical velocity field with multiplier alpha, so u = alpha*b,
where b - some vector field with div b = 0
f - source term calculated from the equation by substitution some analytical function theta satisfying boundary condition for T
so when alpha is small enough (<< 1)
residual = T - theta is tolerable, but
when alpha is >> 1, i obtain something wrong
solution which differs from theta very much.
Be glad to hear any suggestions from you. Thanks.
Old   February 10, 2008, 16:33
Default Did you every look at scalarTr
Hrvoje Jasak
Did you every look at scalarTransportFoam? This is where you should start from:
solve
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(DT, T)
Hrv
Hrvoje Jasak
Old   February 10, 2008, 18:37
Default I've tested your suggestion. I
Dmitry Kovtunov
I've tested your suggestion. It has improved my solution but not enough. I've two problems now:
1) it is not clear how small deltaT need to be choosen to obtain stationary solution;
2) while modeling the solution become unstable on some time step i.e. after some time step an absolute residual become growing up.
Any ideas? And what is the best interpolation scheme for my case? I've noticed filteredLiear to be better than limitedLinear.
Thread Tools
Trackbacks are On
TVD-schemes NewBee Main CFD Forum 4 August 5, 2008 07:03
TVD schemes Shuo Main CFD Forum 3 July 3, 2007 22:04
TVD Schemes Ritesh Main CFD Forum 4 June 16, 2005 10:12
ENO schemes Vinod Venugopalan Main CFD Forum 4 December 10, 2003 01:48
ENO schemes. J. K Main CFD Forum 12 June 28, 2002 11:16
