Von Karman street simulation with icoFoam
Old   February 7, 2008, 14:11
Default I'm trying to run a 2-D vortex
Anant Grewal
agrewal is on a distinguished road
I'm trying to run a 2-D vortex shedding simulation with a circular cylinder in icoFoam. The conditions are u=1 m/s, d = 0.05 m and the comp domain is 1 m in the x direction and 0.5 m in the y-direction.
The BCs are inlet, outlet and symmetric at the top and bottom.
I am using a integration time step of 1e-4 with the following schemes:
ddtSchemes
default CrankNicholson 0.5;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
laplacianSchemes
default none;
laplacian(nu,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(HbyA) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
I also used the following solver settings:
solvers
p PCG
tolerance 1e-07;
relTol 0;
preconditioner DIC;
U smoothSolver
tolerance 1e-07;
relTol 0;
smoother GaussSeidel;
nSweeps 1;
PISO
momentumPredictor yes;
nCorrectors 2;
nNonOrthogonalCorrectors 2;
pRefCell 0;
pRefValue 0;
Before shedding starts, the Courant no blows up and the following message is seen:
#0 Foam::error::printStack(Foam:stream&) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xb7f08420]
#3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&, unsigned char, int) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::GaussSeidelSmoother::smooth(Foam::Field<doub le>&, Foam::Field<double> const&, unsigned char, int) const in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"ddtSche mes
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#6 Foam::fvMatrix<foam::vector<double> >::solve(Foam::Istream&) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoFoam"
#7 Foam::lduMatrix::solverPerformance Foam::solve<foam::vector<double> >(Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoFoam"
#8 main in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoFoam"
#9 __libc_start_main in "/lib/i686/libc.so.6"
#10 Foam::regIOobject::readIfModified() in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoFoam"
Until 0.269 sec, the max Courant # is stable at 0.088, and then starts ramping up.
I use an unstructured mesh with ~9500 tetrahedral prisms. As the solution develops, the outlet region has high velocity including flow reversal that isn't transported from the cylinder. CheckMesh does not report any errors. What am I doing wrong?
Thanks
Anant
agrewal is offline   Reply With Quote
Old   February 7, 2008, 16:22
Default BTW, The Reynolds no is approx
Anant Grewal
BTW, The Reynolds no is approx 350. I am reducing the time step by 10 to see if this overcomes the problem.
Anant
Old   February 9, 2008, 03:14
Default Email your case/ 0, constant a
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Email your case/ 0, constant and system to me, and let me have a look.
Daniel
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   February 9, 2008, 17:12
Default what's about your mesh? Is th
Marhamat Zeinali
marhamat is on a distinguished road
Is the mesh orthogonal enough?
marhamat is offline   Reply With Quote
Video about Karman vortex street simulation Marek Main CFD Forum 0 August 20, 2008 07:54
low Re (30-170) Karman vortex street Sponi FLUENT 0 March 16, 2007 13:27
Karman vortex street gellert OpenFOAM Running, Solving & CFD 15 June 17, 2005 12:19
karman vortex street michael Siemens 5 April 30, 2003 05:04
Von Karman Street JoHn@ Main CFD Forum 0 April 21, 2003 17:12
