Cloning a case or creating a new case for 16 processes |
February 8, 2008, 16:52 |
Hi - I'm new to OpenFOAM.
I
I ran damBreak3d using openMPI over Infiniband with the "runnproc" scripts 1-8. Now I want to try 16 processes and more. My questions is: 1) Should I clone the case = nproc8 and create a "nproc16" with FoamX (FoamX won't start on my system) ? 2) Is it best to create a new case? Is there a way from command line to create a new case? 3) I copied the case "nproc8" and changed "8" to 16 but Foam IO had trouble opening the controlDict file |
Creating a new case from command line | gregh | OpenFOAM Pre-Processing | 25 | November 14, 2013 07:38 |
Creating new case for new user | wersoe | OpenFOAM Pre-Processing | 0 | April 20, 2008 13:03 |
Cloning a case without the GUI using cloneCase function | muerzo | OpenFOAM Pre-Processing | 7 | September 29, 2006 11:07 |
Problem seeing new case in case browser | alan_fergus | OpenFOAM Pre-Processing | 9 | June 22, 2006 03:46 |
Cloning a case from the command line | Daniele Panara (Panara) | OpenFOAM Pre-Processing | 2 | February 1, 2005 09:58 |
