February 7, 2008, 10:07 |
Dear Foamers,
I tried to im
Dear Foamers,
I tried to implement a TimeVaryingUniformFixedValue b.c. for a velocity inlet: inlet.dat: ~~~~~~~~~~ N ( t0 (v1 v2 v3) t1 (v1 v2 v3) t2 (v1 v2 v3) .... tN (v1 v2 v3) ) in 0/U: ~~~~~~~ INLET { type timeVaryingUniformFixedValue; timeDataFileName "inlet.dat"; } But the error message I got when I started the simulation run: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ --> FOAM FATAL IO ERROR : wrong token type - expected Scalar found on line 3 the punctuation token '(' file: inlet.dat at line 3. From function operator>>(Istream&, Scalar&) in file lnInclude/Scalar.C at line 85. FOAM exiting Can anybody tell me what I did wrong? Did I use the right syntax in inlet.dat? Holger
Holger Marschall web: http://www.holger-marschall.info mail: holgermarschall@yahoo.de |
February 7, 2008, 12:54 |
Hello Holger,
Good Evening!
Philippose Rajan
Rep Power: 25 |
Hello Holger,
Good Evening! The TimeVaryingUniformFixedValue boundary condition does not accept vectors in the data file... it can only handle scalars. However, to use this boundary condition in the case of a vector (as in your case, velocity), all you need to do, is to specify the magnitude of the vector. The boundary condition automatically calculates the surface normal of each face on the patch(es) you have specified, and applies the magnitude you have given in the data file along the direction of the surface normal. The sign convention is such that, if you give a positive number for the magnitude in the time data file, the velocity will be pointed into your domain (and as mentioned, in a direction normal to each face on each specified patch). Enjoy and have a nice day! Philippose |
February 7, 2008, 13:12 |
thanks a lot! It wor
thanks a lot! It works now P.S.: I searched even on google for that information. Don't know if somebody has access to http://www.durun.cn/?p=320 and could change the wrong thread there. best regards, Holger
December 17, 2009, 12:25 |
Hi There,
I am trying to have a time dependent inlet-condition. (I want the velocity to raise, since pressure corretion messes up when i start up with the high velocity). But I get a message with which i cant deal. ..... Create mesh for time = 0 Reading g Reading thermophysical properties Reading field T Reading field p Reading field U Expected a '(' while reading VectorSpace<Form, Cmpt, nCmpt>, found on line 27 the doubleScalar 100000 file: /home/OpenFOAM/OpenFOAM-1.6/OWN/jetflame/V4/0/U::value at line 27. From function Istream::readBegin(const char*) in file db/IOstreams/IOstreams/Istream.C at line 87. FOAM exiting ............ the .dat file: ( ( 0.00005 ( 0 0 0.1000 ) ) ( 0.00010 ( 0 0 0.2058 ) ) ( 0.00015 ( 0 0 0.3116 ) ) ( 0.00020 ( 0 0 0.4174 ) ) ( 0.00025 ( 0 0 0.5232 ) ) ( 0.00030 ( 0 0 0.6290 ) ) ( 0.00035 ( 0 0 0.7348 ) ) ( 0.00040 ( 0 0 0.8406 ) ) ( 0.00045 ( 0 0 0.9464 ) ) ( 0.00050 ( 0 0 1.0522 ) ) ( 0.00055 ( 0 0 1.1580 ) ) ( 0.00060 ( 0 0 1.2638 ) ) ( 0.00065 ( 0 0 1.3696 ) ) ( 0.00070 ( 0 0 1.4754 ) ) ( 0.00075 ( 0 0 1.5812 ) ) ( 0.00080 ( 0 0 1.6870 ) ) ( 0.00085 ( 0 0 1.7928 ) ) ( 0.00090 ( 0 0 1.8986 ) ) ( 0.00095 ( 0 0 2.0044 ) ) ( 0.00100 ( 0 0 2.1102 ) ) ( 0.00105 ( 0 0 2.2160 ) ) ( 0.00110 ( 0 0 2.3218 ) ) ( 0.00115 ( 0 0 2.4276 ) ) ( 0.00120 ( 0 0 2.5334 ) ) ( 0.00125 ( 0 0 2.6392 ) ) ( 0.00130 ( 0 0 2.7450 ) ) ( 0.00135 ( 0 0 2.8508 ) ) // line 27 (stating from line 0) ( 0.00140 ( 0 0 2.9566 ) ) ( 0.00145 ( 0 0 3.0624 ) ) ( 0.00150 ( 0 0 3.1682 ) ) ( 0.00155 ( 0 0 3.2740 ) ) ( 0.00160 ( 0 0 3.3798 ) ) ( 0.00165 ( 0 0 3.4856 ) ) ( 0.00170 ( 0 0 3.5914 ) ) ( 0.00175 ( 0 0 3.6972 ) ) ( 0.00180 ( 0 0 3.8030 ) ) ( 0.00185 ( 0 0 3.9088 ) ) ( 0.00190 ( 0 0 4.0146 ) ) ( 0.00195 ( 0 0 4.1204 ) ) ........... I cant find a missing "(" and there is no value "100000" -> Any Ideas???? regards Last edited by heavy_user; December 18, 2009 at 04:30. |
August 10, 2013, 14:47 |
#5 | |
Islam Elqatary
Does anyone know how to change the inlet speed direction with time? like if I want to change the angle of attack on the airfoil with time thanks |
TimeVaryingUniformFixedValue BC in foam 15 | nzy102 | OpenFOAM Running, Solving & CFD | 5 | August 19, 2008 08:08 |
TimeVaryingUniformFixedValue with sonicLiquidFoam Bugs amp Fixes | chnrdu | OpenFOAM Bugs | 1 | May 21, 2008 09:52 |
TimeVaryingUniformFixedValue does not work as a pressureInlet with sonicLiquidFoam | nishant_hull | OpenFOAM Running, Solving & CFD | 5 | May 21, 2008 08:54 |
TimeVaryingUniformFixedValue boundary condition | liu | OpenFOAM Running, Solving & CFD | 1 | October 12, 2007 13:19 |
