-   -   Pressure not converging (http://www.cfd-online.com/Forums/openfoam-solving/59163-pressure-not-converging.html)
johndeas February 7, 2008 13:09
Hi, to make some performanc
to make some performance test for a parallel run of OpenFoam, I took the icoFoam/cavity tutorial case and increased the density of the mesh. It turns out that, if I use a 800x800x1 mesh and run it on 4 processors, the velocity solver do 4/5 iterations per component, but the pressure solver reaches a limit of 1001 iterations, and the associated residual is well above 1e-6.
I have decreased the timestep so that the Courant Number value does not explode.
I would like to know if there is a way to get a converged solution for the pressure when I increase the density of the grid.
thanks,
jd
