Open Mpi on AMD 64 cluster
Old   February 4, 2008, 07:13
Default Hi all, I am trying to run
Nishant
nishant_hull is on a distinguished road
Hi all,
I am trying to run interfoam simulation using mpirun on 4 processor.
I am getting following error.
I have password-free access to the all nodes and I can see the same set-up file on all computer nodes from my pc. (I do not copied it individually though!)
The error I am receiving is as follows:-
e343880@comp02:~/OpenFOAM/e343880-1.4.1/run/tutorials/interFoam> mpirun --hostfile machines -np 4 interFoam . dam-dumy -parallel
MPI Pstream initialized with:
floatTransfer : 1
nProcsSimpleSum : 0
scheduledTransfer : 0
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
[2] Date : Feb 04 2008
[2] Time : 12:00:38
[2] Host : comp00
[2] PID : 22833
[3] Date : Feb 04 2008
[3] Time : 12:00:38
[3] Host : comp00
[3] PID : 22834
Exec : interFoam . dam-dumy -parallel
[0] Date : Feb 04 2008
[0] Time : 12:00:38
[0] Host : kittyhawk
[0] PID : 30155
[1] Date : Feb 04 2008
[1] Time : 12:00:38
[1] Host : kittyhawk
[1] PID : 30156
[1] Root : /users/e343880/OpenFOAM/e343880-1.4.1/run/tutorials/interFoam
[1] Case : dam-dumy
[1] Nprocs : 4
[1]
[1]
[1] --> FOAM FATAL IO ERROR : cannot open file
[1]
[1] file: /users/e343880/OpenFOAM/e343880-1.4.1/run/tutorials/interFoam/dam-dumy/processor 1/system/controlDict at line 0.
[1]
[1] From function regIOobject::readStream(const word&)
[1] in file db/regIOobject/regIOobjectRead.C at line 66.
[1]
FOAM parallel run exiting
[1]
[kittyhawk:30156] MPI_ABORT invoked on rank 1 in communicator MPI_COMM_WORLD with errorcode 1
mpirun noticed that job rank 0 with PID 30155 on node kittyhawk.dcs.hull.ac.uk exited on signal 15 (Terminated).
2 additional processes aborted (not shown)
My machine file is shown below:-
\attach { machine }
Please suggest!
regards,
Nishant
Thanks and regards,
Nishant
nishant_hull is offline   Reply With Quote
Old   February 4, 2008, 07:14
Nishant
Thanks and regards,
Nishant
Old   February 4, 2008, 07:15
Default machine file is: kittyhawk.
Nishant
machine file is:
kittyhawk.dcs.hull.ac.uk slots=2 max-slots=2
comp00.dcs.hull.ac.uk slots=4 max-slots=4
comp01.dcs.hull.ac.uk slots=4 max-slots=4
comp02.dcs.hull.ac.uk slots=4 max-slots=4
comp03.dcs.hull.ac.uk slots=4 max-slots=4
comp04.dcs.hull.ac.uk slots=4 max-slots=4
comp05.dcs.hull.ac.uk slots=4 max-slots=4
comp06.dcs.hull.ac.uk slots=4 max-slots=4
comp07.dcs.hull.ac.uk slots=4 max-slots=4
comp08.dcs.hull.ac.uk slots=4 max-slots=4
comp09.dcs.hull.ac.uk slots=4 max-slots=4
comp10.dcs.hull.ac.uk slots=4 max-slots=4
comp11.dcs.hull.ac.uk slots=4 max-slots=4
comp12.dcs.hull.ac.uk slots=4 max-slots=4
comp13.dcs.hull.ac.uk slots=4 max-slots=4
comp14.dcs.hull.ac.uk slots=4 max-slots=4
comp15.dcs.hull.ac.uk slots=4 max-slots=4
comp16.dcs.hull.ac.uk slots=4 max-slots=4
comp17.dcs.hull.ac.uk slots=4 max-slots=4
Thanks and regards,
Nishant
Old   February 4, 2008, 08:22
Default Nishant! If you don't have a
Michele Vascellari
mighelone is on a distinguished road
Nishant!
If you don't have a shared filesystem (NFS), you have to copy the directory processor2 on the corresponding filesystem of processor2 node, and so on.
Michele
mighelone is offline   Reply With Quote
Old   February 4, 2008, 08:47
Default Thanks for the reply Michele,
Nishant
Well, whenever i ssh to other nodes of the cluster, I can see the same file what I see on master node. If NFS mean that then I guess, I have NFS system here.
But I would lik to know where I went wrong??
Nishant
Thanks and regards,
Nishant
Old   February 4, 2008, 12:16
Default After some modification I am g
Nishant
After some modification I am getting this error:-
[2] Time : 17:13:39
[2] Host : comp00
[2] PID : 25855
floatTransfer : 1
nProcsSimpleSum : 0
[0] Time : 17:13:39
[0] PID : 28172
[0] Root : /users/e343880/OpenFOAM/e343880-1.4.1/run/tutorials/interFoam
[0] Case : dam-dumy
[0] Nprocs : 4
[0] Slaves :
[0] 3
[0] (
[0] kittyhawk.28173
[0] comp00.25855
[0] comp00.25856
[0] )
[0]
[3] Time : 17:13:39
[0]
[0]
[0] --> FOAM FATAL ERROR : interFoam: Cannot open case directory "/users/e343880/OpenFOAM/e343880-1.4.1/run/tutorials/interFoam/dam-dumy/processo r0"
[0]
[0]
[0]
[kittyhawk:28172] MPI_ABORT invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1
[3] Host : comp00
[1] Time : 17:13:39
[1] PID : 28173
[1] Case : dam-dumy
[1] Nprocs : 4
[3] PID : 25856
[1]
[1]
[1]
[1]
[1]
[1]
[kittyhawk:28173] MPI_ABORT invoked on rank 1 in communicator MPI_COMM_WORLD with errorcode 1
[2] Root : /users/e343880/OpenFOAM/e343880-1.4.1/run/tutorials/interFoam
[2] Case : dam-dumy
[2] Nprocs : 4
[3] Root : /users/e343880/OpenFOAM/e343880-1.4.1/run/tutorials/interFoam
[3] Case : dam-dumy
[3] Nprocs : 4
[2]
[2]
[2] --> FOAM FATAL IO ERROR : cannot open file
[2]
[2] file: /users/e343880/OpenFOAM/e343880-1.4.1/run/tutorials/interFoam/dam-dumy/processor 2/system/controlDict at line 0.
[2]
[2] From function regIOobject::readStream(const word&)
[2] in file db/regIOobject/regIOobjectRead.C at line 66.
[2]
[2]
[comp00:25855] MPI_ABORT invoked on rank 2 in communicator MPI_COMM_WORLD with errorcode 1
[3]
[3]
[3] --> FOAM FATAL IO ERROR : cannot open file
[3]
[3] file: /users/e343880/OpenFOAM/e343880-1.4.1/run/tutorials/interFoam/dam-dumy/processor 3/system/controlDict at line 0.
[3]
[3] From function regIOobject::readStream(const word&)
[3] in file db/regIOobject/regIOobjectRead.C at line 66.
[3]
[3]
[comp00:25856] MPI_ABORT invoked on rank 3 in communicator MPI_COMM_WORLD with errorcode 1
mpirun noticed that job rank 1 with PID 28173 on node kittyhawk.dcs.hull.ac.uk exited on signal 1 (Hangup).
Please suggest!
regards..
Nishant
Thanks and regards,
Nishant
Old   February 4, 2008, 18:20
Default I too have just started playin
Andrew Burns
andrewburns is on a distinguished road
I too have just started playing with parallel and I'm getting an error very similar to this (just for my case)
I've looked and none of the processor folders in the case folder have system/controlDict even though decomposePar ran correctly and I believe is set up correctly.
andrewburns is offline   Reply With Quote
An Open Source mesh generator for Open Foam Ahmed Main CFD Forum 15 September 23, 2010 18:39
192 CPU HPC Cluster Available Steve Booth Main CFD Forum 0 September 24, 2007 14:05
PC-cluster Chris Main CFD Forum 14 January 27, 2000 18:40
CFD on PC (cluster) Bambang I. Soemarwoto Main CFD Forum 2 October 9, 1998 13:12
