I'm new with OpenFoam and I ha
I'm new with OpenFoam and I have a question about BouyantFoam:
If fvSolution of BouyantFoam works with PISO, also i have to write rho, h, k, etc in SOLVERS?? If this not the case, where put this constants? Thank!! |
Hi Antonieta,
You mis-spell
Hi Antonieta,
You mis-spelled Buoyant in your title. You might try here for some answers, as this title (correctly spelled) is already on the lists. http://www.cfd-online.com/OpenFOAM_D...tml?1190235325 Briefly, you need to look at the solver. buoyantFoam uses the heatTransfer solver located here: /applications/solvers/heatTransfer So, even though I haven't used this solver before, I just look at buoyantFoam.C and createfields.H, and immediately see that rho and h are being declared through the thermophysicalmodels directory in the src directory; in particular, they are unknowns here that are beings solved, and not constants. If you want to see this in paraview, then I think you need to create an IOobject for, say, the enthalpy; which is not currently listed in createFields.H. Anyway, I would recommend reading through a bunch of the discussion here, the user and programmers manual, and then take a look at the code for the solver. Things should start to become clearer at that point. Hope this helps some. Evan |
Dear Evan:
Thank for your a
Dear Evan:
Thank for your answer! First at all, yes, it's BuoyantFoam and not Bouyant. Second... how I create an IOobject?? or where I find how create... I read a lot about this, but there a lot of things that I don't understand yet, and this is one of them... for this reason I asked... Thank again.. Antonieta |
Maybe try to add in createfiel
Maybe try to add in createfield.H, for the h field for example, the following:
volScalarField h ( IOobject ( "h" runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), thermo->h() ); remove the volScalarField& h assignment, recompile. and try the case again. Evan |
Dear Evan:
When I do that,
Dear Evan:
When I do that, I should see a new field h?? something happen when I do that?? Because all is the same... Sorry for the basic questions but I never do this before... Antonieta |
Hi Antonieta,
Not sure what
Hi Antonieta,
Not sure what to tell you right now. I think that should have worked. Are you sure the field isn't being written in your case file? I will try it here in the next couple days on the buoyantFoam tutorial to see if it works for me (sorry, I am a bit busy at the moment), but I have done this for other solvers without trouble. You could also change the IOobject to mesh and MUST_READ, like explained here: http://www.cfd-online.com/cgi-bin/Op...show.cgi?1/878 But then you might need to write a boundary condition for the field in the tutorial 0 time directory. Good luck. Evan |
Antonieta,
Yeah, sorry, so
Antonieta,
Yeah, sorry, so my suggestion didn't work; I just tried it myself. Tried a couple of other things, but to no avail. I'll keep at it, and let you know if I figure it out. Evan |
Hi, I'm a new user of OpenFOAM
Hi, I'm a new user of OpenFOAM and I have a little problem.
I want create a room with a radiator. At first I use buoyantSimpleFoam ... but I think thats not the best Solver, because it is for steadystate. Therefore a try it with buoyantFoam. My problem is deltaT, because U should be 0. (deltaT=Co*dx/U) How I define deltaT? thanks for your help! |
Evan:
Thank... i tried othe
Evan:
Thank... i tried other things too, but i I haven't had success. I hope you have luck.. Antonieta |
