Hi Manuel.
Thanks for your
Hi Manuel.
Thanks for your reply. http://www.cfd-online.com/OpenFOAM_D...part/happy.gif You're right! I'm solving coupled equations. I'll contact alberto. Good luck to your work!!! kind regards, Hyunchang |
Hi again Dragos!
I probe wi
Hi again Dragos!
I probe with laplacianFoam solver, and my program run, but when I see the results in paraview, nothing change... the temperature behavior is always the same, don't change with time... I review all, and I don't know what's wrong... If you have an idea of which can be my mistake, i will be grateful. Antonieta |
If you start from a constant t
If you start from a constant temperature field and the same value for the boundaries, then nothing should change, but this is just a guess since I don't know your settings.
What is your initial field and what are the values at the boundaries? Dragos |
The inside of the sphere is a
The inside of the sphere is a 1000 and the surface a 100. With this values, the sphere should be colder... but nothing happen.... Ah! my DT=1.477E-5.
Antonieta |
