SimpleFoam convergence criterion?
Like Tree17Likes
  • 1 Post By phsieh2005
  • 8 Post By alberto
  • 1 Post By alberto
  • 2 Post By alberto
  • 4 Post By alberto
  • 1 Post By Andrew_Sm
Old   August 13, 2011, 09:57
Default SimpleFoam convergence criterion?
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
I am running a simpleFoam case. The print out messages said that, there is no convergence criterion. The case will run for 1000 steps. What is the reason behind it?
Thanks!
Pei
pela145 likes this.
phsieh2005 is offline   Reply With Quote
Old   August 14, 2011, 23:46
Alberto Passalacqua
This happens because the convergence criterion is not specified in fvSolution.
If you use OpenFOAM 1.7.x, you need to specify it in the SIMPLE sub-dictionary:
SIMPLE
  nNonOrthogonalCorrectors 0;
  // Residual here (all residuals must go below this)
  convergenceCriterion 1.0e-6;
If you use OpenFOAM 2.0.x, the syntax is:
SIMPLE
    // Residuals here (one per variable)
    // If one variable is not specified, zero is assumed as
    // desired residual (iterations will not stop)
    residualControl
        p               1e-2;
        U               1e-3;
        "(k|epsilon|omega)" 1e-3;
I hope this helps.
atg, hawkeye321, JR22 and 5 others like this.
Alberto Passalacqua
Old   August 16, 2011, 09:12
Alex
bigbang is on a distinguished road
Thanks Alberto, this has helped me.
When I run simpleFoam, I now get this:
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model realizableKE
realizableKECoeffs
    Cmu             0.09;
    A0              4;
    C2              1.9;
    sigmak          1;
    sigmaEps        1.2;
SIMPLE: convergence criteria
    field p	 tolerance 1e-06
    field U	 tolerance 1e-06
    field k	 tolerance 1e-06
    field epsilon	 tolerance 1e-06
Starting time loop
Time = 1
bigbang is offline   Reply With Quote
Old   September 19, 2011, 09:01
rgarcia is on a distinguished road
Hi all,
I would like to know what exactly happens if you introduce
SIMPLE
Does the simulation stop when all the variables has a residual lower than 1.0e-6?
Do you know if it's possible to stop the simulation when the residuals are lower of 1.0e-4 for 50 consecutive iterations instead of loooking just one iteration?
Thanks in advance!
Roger
rgarcia is offline   Reply With Quote
Old   June 20, 2012, 16:36
cfddwarf is on a distinguished road
In my Log file it also says:
SIMPLE: no convergence criteria found. Calculations will run for 2000 steps.
In the fvSolution file entry looks as follows:
SIMPLE
so my question is, whether the solver is now trying to reach zero as the desired residual? Are my simulations still correct??
Thanks for any answer...
cfddwarf is offline   Reply With Quote
Old   June 20, 2012, 16:39
Alberto Passalacqua
Your results will simply have the residuals the solution gives after 2000 iterations. If such a number of iterations is sufficient for your case, the solution will be correct.
You can store the output of the solver in a text file and then examine them using foamLog.
Alternatively, you can specify residuals (see tutorials).
SHANRU likes this.
Alberto Passalacqua
Old   June 20, 2012, 16:46
At approximately timestep 500 the no of iterations change to zero.
Time = 572
DILUPBiCG: Solving for Ux, Initial residual = 8.02058e-06, Final residual = 8.02058e-06, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 9.42366e-06, Final residual = 9.42366e-06, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 8.13976e-06, Final residual = 8.13976e-06, No Iterations 0
DICPCG: Solving for p, Initial residual = 1.09339e-05, Final residual = 9.86413e-07, No Iterations 70
time step continuity errors : sum local = 0.000183096, global = -8.98498e-07, cumulative = 0.00553493
ExecutionTime = 5461.38 s ClockTime = 5489 s
Does this mean it converged? How come the other entries in the fvSolution file dont play a role for the convergence criterion? I mean the entries "tolerance" and "reltol"??
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.01;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0.1;
Old   June 20, 2012, 16:55
Alberto Passalacqua
They actually played a role. If you want convergence with a specified residual specify your criteria in fvSolution / SIMPLE
SIMPLE
    pRefCell        0;
    pRefValue       0;
    residualControl
        p               1e-5;
        U               1e-5;
        // Add other variables here
lav and sr71blackbird like this.
Alberto Passalacqua
Old   July 20, 2012, 08:26
Default a recommandable convergence criterium?
Sören
despaired student is on a distinguished road
how do you specify your convergence criteria? I mean how do you know that the residual must be below e.g. 10^-5 to definitely reach convergence? I first was looking at my residuals to not fluctuate any more (ideal case would be a horizontal line but I've never reached that) but the chief-engineer told me that I must reach a convergence criteria of 10^-5 at least. He said that it is a normally used criteria... but why...???
Can you help me with this question???
Attached are some pictures of my residuals. I would like to read your opinion - does these pictures proof convergence or not?
This is kind of important for my graduating thesis...
Thank you
despaired student is offline   Reply With Quote
Old   July 20, 2012, 16:48
Alberto Passalacqua
Hi Soren,
your plot show the solution behaviour is correct, and the solution is converging. However, for a steady-state solution, residuals are usually required to be very small (ideally close to machine precision) to declare the solution is converged.
Also, note that at convergence, residual curves should be flat. In your case their slope is not negligible, indicating that the solution convergence can be further improved.
I usually set convergence criteria to a very small number (1.0e-12), let the simulation run for a good number (depends on the case) of iterations, and then check the residual curves. If residuals reach 1.0e-12 or if they decreased many orders of magnitude and they stopped changing for a certain number of iterations, then I consider the solution converged.
Best,
Claudio87, JR22, wayne14 and 1 others like this.
Alberto Passalacqua
Old   March 3, 2015, 05:56
Default Simple Foam stops before reaching the end iteration
  #11
Naresh Yathuru
Naresh yathuru is on a distinguished road
Hi can some one help me out.
1. the simple foam stops in the middle with out any error.
tolerance= 1 e^-09
reltol= 1 e^-o9
There is a huge difference between my initial and final residuals. is it ok?
(approx) initial residuals= 2.4 e--4
final residuals= 6.2 e-10
so still the initial residuals are higher than the tolerance but why does the simulation stops? By stop i mean it gets stuck at a itereation and its not proceeding any further. i waited for almost an hour.
can some one help me.
Thank you
Regards,
Naresh
Naresh yathuru is offline   Reply With Quote
Old   March 3, 2015, 06:29
Andrew Smith
Andrew_Sm is on a distinguished road
tolerance= 1 e^-09
reltol= 1 e^-o9
Thank you
Regards,
Naresh
Running OpenFoam successfully is not everyone's cup of tea
You gave very less information so I suggest you to first refer the "User guide of OF" and try some basic tutorials before jumping on to anything
Advice:
For tutorials refer the following post:
http://www.cfd-online.com/Forums/ope...-chalmers.html
gabrielfelix likes this.
Andrew_Sm is offline   Reply With Quote
Old   March 3, 2015, 07:44
Naresh Yathuru
Thank Andrew or your quick reply.
I m trying to simulate a room with inlet and outlet and a box inside in simple foam.
This is my FVscheme
ddtSchemes
default steadyState;
gradSchemes
default leastSquares;//Gauss linear
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwind grad(U); // was bounded Gauss upwind which is first order but linearupwind is second order
div(phi,k) bounded Gauss upwind;
div(phi,epsilon) bounded Gauss upwind;
div(phi,omega) bounded Gauss upwind;
div(phi,R) bounded Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) bounded Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
And this is my FVsolution
solvers
p
solver GAMG;
tolerance 1e-12;
relTol 1e-12;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
"(U|k|epsilon|omega|R|nuTilda)"
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-12;
relTol 1e-12;
SIMPLE
/* residualControl
p 1e-2;
U 1e-3;
}*/ //as of we do not need
relaxationFactors
fields
p 0.7; // Before 0.3 :it means that 30 percentage of the ew value and 70 % of old value weighted to gether foe the next iteration.
} // It helps in stability but takes longer for convergence.
equations
U 0.3;
k 0.7;
epsilon 0.7;
omega 0.7;
R 0.7;
nuTilda 0.7;
1. i ran the simulation for 5000 iterations but with no sucess for convergence.
then i changed the relaxation factor for p and u.
before :
p= 0.3
u=0.7
now:
p= 0.7
u= 0.3
The simulation runs for some 50 iterations and the iteration get stuck at some point and its not going further.
Interesting is that the Initial residuals are lesser than the specified tolerance.
Time = 5517
smoothSolver: Solving for Ux, Initial residual = 0.00026747233, Final residual = 4.3957841e-14, No Iterations 7
smoothSolver: Solving for Uy, Initial residual = 0.00035219196, Final residual = 5.6268315e-14, No Iterations 7
smoothSolver: Solving for Uz, Initial residual = 0.000529688, Final residual = 8.2691583e-14, No Iterations 7
GAMG: Solving for p, Initial residual = 0.0062565687, Final residual = 9.9888366e-13, No Iterations 143
time step continuity errors : sum local = 2.4610067e-14, global = 5.1314876e-17, cumulative = 1.6021426e-16
smoothSolver: Solving for omega, Initial residual = 0.00023592505, Final residual = 7.3934347e-13, No Iterations 17
smoothSolver: Solving for k, Initial residual = 0.0003149381, Final residual = 9.8133224e-13, No Iterations 18
ExecutionTime = 943.83 s ClockTime = 951 s
Time = 5518
smoothSolver: Solving for Ux, Initial residual = 0.00026770097, Final residual = 4.3982852e-14, No Iterations 7
smoothSolver: Solving for Uy, Initial residual = 0.00035250148, Final residual = 5.6302256e-14, No Iterations 7
smoothSolver: Solving for Uz, Initial residual = 0.00053021843, Final residual = 8.2741381e-14, No Iterations 7
GAMG: Solving for p, Initial residual = 0.0062455933, Final residual = 9.9992215e-13, No Iterations 150
time step continuity errors : sum local = 2.4576868e-14, global = 5.0798341e-17, cumulative = 2.110126e-16
smoothSolver: Solving for omega, Initial residual = 0.00023601326, Final residual = 7.3802878e-13, No Iterations 17
smoothSolver: Solving for k, Initial residual = 0.00031391878, Final residual = 9.7660363e-13, No Iterations 18
where would i have possibly gone wrong. Thank you for your help in advance .
Regards,
Naresh
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Definition of convergence criterion in simpleFoam titio OpenFOAM Running, Solving & CFD 1 February 6, 2010 01:34
convergence criterion Dominique FLUENT 5 November 24, 2006 02:36
Setting convergence criterion Vidya FLUENT 5 August 6, 2006 16:46
