How to specify BC as a function compiled in solver |
January 29, 2008, 09:50 |
Recently I've been "
Kārlis Repsons
Rep Power: 17 |
Recently I've been "playing" with OF quite a lot, but haven't found how to do that thing. For example I would like to write some time dependant, nonlinear C++ function for temperature on boundary. Let x,y be local coordinates on boundary surface, t - time, so I want to use BC T = T(x,y,t). Or T gradient. If local coordinates is a problem, I don't mind writing that function for global ones. How to do this? |
January 29, 2008, 15:36 |
Search for parabolic inlet...
Search for parabolic inlet... I remember a discussion about that earlier.
January 29, 2008, 16:30 |
@martin:
The parabolic-inlet
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
@martin:
The parabolic-inlet is not time-dependent. He will need a "real" boundary condition. @karlis: Have a look at $FOAM_SRC/finiteVolume/fields/fvPatchFields/derived/timeVaryingUniformFixedValue / as a starting point (the parabolic stuff might give you an idea how to implement the spatial part of the function)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
Help for compiled UDF | Tim | FLUENT | 1 | April 8, 2011 03:56 |
Control function in Elliptic solver | Hoang Anh Duong | Main CFD Forum | 4 | July 9, 2007 03:32 |
Solver and density function for high speed vapour | christian | OpenFOAM Running, Solving & CFD | 17 | April 12, 2007 02:41 |
Stream Function - Potential Function coordinates | harish | Main CFD Forum | 8 | June 25, 2005 13:18 |
compiled function | David | FLUENT | 2 | March 31, 2005 07:37 |
