Home > Forums > OpenFOAM Running, Solving & CFD
How to specify BC as a function compiled in solver
Old   January 29, 2008, 10:50
Default Hello, Recently I've been "
kar
Kārlis Repsons
kar is on a distinguished road
Recently I've been "playing" with OF quite a lot, but haven't found how to do that thing. For example I would like to write some time dependant, nonlinear C++ function for temperature on boundary. Let x,y be local coordinates on boundary surface, t - time, so I want to use BC T = T(x,y,t). Or T gradient. If local coordinates is a problem, I don't mind writing that function for global ones.
How to do this?
kar is offline   Reply With Quote
Old   January 29, 2008, 16:36
Default Search for parabolic inlet...
unoder
Search for parabolic inlet... I remember a discussion about that earlier.
Old   January 29, 2008, 17:30
Default @martin: The parabolic-inlet
Assistant Moderator
Bernhard Gschaider
@martin:
The parabolic-inlet is not time-dependent. He will need a "real" boundary condition.
@karlis:
Have a look at $FOAM_SRC/finiteVolume/fields/fvPatchFields/derived/timeVaryingUniformFixedValue / as a starting point (the parabolic stuff might give you an idea how to implement the spatial part of the function)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Thread Tools
Trackbacks are On
Help for compiled UDF Tim FLUENT 1 April 8, 2011 03:56
Control function in Elliptic solver Hoang Anh Duong Main CFD Forum 4 July 9, 2007 03:32
Solver and density function for high speed vapour christian OpenFOAM Running, Solving & CFD 17 April 12, 2007 02:41
Stream Function - Potential Function coordinates harish Main CFD Forum 8 June 25, 2005 13:18
compiled function David FLUENT 2 March 31, 2005 07:37
